08-19-2025 05:27 PM - editado 08-19-2025 05:27 PM
I am experiencing flap issues on my Cisco 9300 devices. These are connected to 9200 access switches, creating redundancy with two core switches (9300). The access switches have two uplink ports, one connected to each core switch. I have reviewed the spanning-tree, port-channel, and trunk configurations and have not detected any inconsistencies. All devices are provisioned in DNA Center.
When executing a show mac address for the MAC, it is observed that it oscillates between ports 21 and 22. I also checked for multiple MAC addresses on an access port to identify any out-of-standard switches, but nothing was found. No physical loop was detected either.
witch Ports Model SW Version SW Image Mode
* 1 52 C9200L-48P-4X 17.09.04a CAT9K_LITE_IOSXE INSTALL
cm_tr_p2c_cabecera1_9300#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) PAgP Gi1/0/23(P) Gi1/0/24(P)
cm_tr_p2c_cabecera1_9300# sh int trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/20 on 802.1q trunking 1
Gi1/0/21 on 802.1q trunking 1
Gi1/0/22 on 802.1q trunking 1
Te1/1/1 on 802.1q trunking 1
Po1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/0/20 19,32,126,132
Gi1/0/21 19,32,126,132
Gi1/0/22 19,32,126,132
Te1/1/1 310,320
Po1 19,32,126,132
Port Vlans allowed and active in management domain
Te1/1/1 310,320
Po1 19,32,126,132
Port Vlans in spanning tree forwarding state and not pruned
Te1/1/1 310,320
Po1 19,32,126,132
cm_tr_p2c_cabecera1_9300# sh vl br
VLAN Name Status Ports
1 default active Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7, Gi1/0/8, Gi1/0/9, Gi1/0/10, Gi1/0/11, Gi1/0/12
Gi1/0/13, Gi1/0/14, Gi1/0/15, Gi1/0/16, Gi1/0/17, Gi1/0/18, Gi1/0/19, Te1/1/2, Te1/1/3, Te1/1/4, Te1/1/5
Te1/1/6, Te1/1/7, Te1/1/8, Ap1/0/1
19 Admin_y_Ospf active
32 Lan1 active
126 telefonia active
132 ToIP_P2C active
310 WAN_DATOS active
320 WAN_VOZ active
400 VLAN0400 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
cm_tr_p2c_cabecera1_9300# sh mac add ad c85a.cfa6.c721
Mac Address Table
Vlan Mac Address Type Ports
32 c85a.cfa6.c721 DYNAMIC Gi1/0/22
Total Mac Addresses for this criterion: 1
Mac Address Table
32 c85a.cfa6.c721 DYNAMIC Gi1/0/21
el 08-21-2025 02:12 AM
Any update
MHM
el 08-21-2025 05:47 AM
The VLAN 126 was completely removed since it is not being used; however, flap logs are still appearing. All switches are running rapid-PVST, but the Layer 2 switches only have the following configuration:
"spanning-tree mode rapid-pvst
spanning-tree extend system-id"
cm_tr_p2c_cabecera1_9300#sh spanning-tree int GigabitEthernet1/0/20 de
Port 20 (GigabitEthernet1/0/20) of VLAN0019 is designated forwarding
Port path cost 20000, Port priority 128, Port Identifier 128.20.
Designated root has priority 19, address c47e.e094.5e00
Designated bridge has priority 19, address c47e.e094.5e00
Designated port id is 128.20, designated path cost 0
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 1
Link type is point-to-point by default
BPDU: sent 2570034, received 17
Port 20 (GigabitEthernet1/0/20) of VLAN0032 is designated forwarding
Designated root has priority 32, address c47e.e094.5e00
Designated bridge has priority 32, address c47e.e094.5e00
Port 20 (GigabitEthernet1/0/20) of VLAN0132 is designated forwarding
Designated root has priority 132, address c47e.e094.5e00
Designated bridge has priority 132, address c47e.e094.5e00
cm_tr_p2c_cabecera1_9300#sh spanning-tree int GigabitEthernet1/0/21 de
Port 21 (GigabitEthernet1/0/21) of VLAN0019 is designated forwarding
Port path cost 20000, Port priority 128, Port Identifier 128.21.
Designated port id is 128.21, designated path cost 0
BPDU: sent 2570038, received 13
Port 21 (GigabitEthernet1/0/21) of VLAN0032 is designated forwarding
Port 21 (GigabitEthernet1/0/21) of VLAN0132 is designated forwarding
cm_tr_p2c_cabecera1_9300#sh spanning-tree int GigabitEthernet1/0/22 de
Port 22 (GigabitEthernet1/0/22) of VLAN0019 is designated forwarding
Port path cost 20000, Port priority 128, Port Identifier 128.22.
Designated port id is 128.22, designated path cost 0
BPDU: sent 2570047, received 14
Port 22 (GigabitEthernet1/0/22) of VLAN0032 is designated forwarding
BPDU: sent 2570047, received 13
Port 22 (GigabitEthernet1/0/22) of VLAN0132 is designated forwarding
el 08-22-2025 02:03 AM
VLAN0019 Desg FWD 15 128.20 P2p
VLAN0032 Desg FWD 15 128.20 P2p
VLAN0126 Desg FWD 15 128.20 P2p
VLAN0132 Desg FWD 20000 128.20 P2p
el 08-22-2025 09:20 AM
It is because the port has MAB/802.1X authentication enabled. When the ISE is removed from the port, the MAC appears as type “Dynamic.”
el 08-22-2025 09:26 AM
Yes friend I know but host is connect to cat92001 abd appear to flapping between port connect to both cat92002 and cat92003 (21/22)
el 08-21-2025 07:17 AM
el 08-21-2025 07:31 AM
08-21-2025 07:31 AM - editado 08-21-2025 07:32 AM
Attached is the current topology.
SW1_ACCESO_TR_P2C#sh spanning-tree blockedports
Name Blocked Interfaces List
VLAN0019 Gi1/0/48
VLAN0032 Gi1/0/48
VLAN0132 Gi1/0/48
Number of blocked ports (segments) in the system : 3
SW1_ACCESO_TR_P2C#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
cm_tr_p2c_cabecera1_9300.banco.bestado.cl
Gig 1/0/47 160 R S I C9300-24T Gig 1/0/20
cm_tr_p2c_cabecera2_9300.banco.bestado.cl
Gig 1/0/48 178 R S I C9300-24T Gig 1/0/20
Total cdp entries displayed : 2
SW1_ACCESO_TR_P2C#
SW2_ACCESO_TR_P2C#sh spanning-tree blockedports
VLAN0019 Gi1/0/48
VLAN0032 Gi1/0/48
VLAN0132 Gi1/0/48
SW2_ACCESO_TR_P2C#sh cdp nei
Gig 1/0/47 174 R S I C9300-24T Gig 1/0/21
Gig 1/0/48 178 R S I C9300-24T Gig 1/0/21
SW2_ACCESO_TR_P2C#
SW3_ACCESO_TR_P2C#sh spanning-tree blockedports
VLAN0019 Gi1/0/48
VLAN0032 Gi1/0/48
VLAN0132 Gi1/0/48
SW3_ACCESO_TR_P2C#sh cdp nei
Gig 1/0/47 159 R S I C9300-24T Gig 1/0/22
Gig 1/0/48 171 R S I C9300-24T Gig 1/0/22
SW3_ACCESO_TR_P2C#
el 08-21-2025 07:51 AM
cm_tr_p2c_cabecera1_9300#sh cdp nei Gig 1/0/20
SW1_ACCESO_TR_P2C.banco.bestado.cl
Gig 1/0/20 160 S I C9200L-48 Gig 1/0/47
Total cdp entries displayed : 1
cm_tr_p2c_cabecera1_9300#sh cdp nei Gig 1/0/21
SW2_ACCESO_TR_P2C.banco.bestado.cl
Gig 1/0/21 148 S I C9200L-48 Gig 1/0/47
cm_tr_p2c_cabecera1_9300#sh cdp nei Gig 1/0/22
SW3_ACCESO_TR_P2C.banco.bestado.cl
Gig 1/0/22 168 S I C9200L-48 Gig 1/0/47
cm_tr_p2c_cabecera2_9300#sh cdp nei Gig 1/0/20
Gig 1/0/20 135 S I C9200L-48 Gig 1/0/48
cm_tr_p2c_cabecera2_9300#sh cdp nei Gig 1/0/21
Gig 1/0/21 148 S I C9200L-48 Gig 1/0/48
cm_tr_p2c_cabecera2_9300#sh cdp nei Gig 1/0/22
Gig 1/0/22 166 S I C9200L-48 Gig 1/0/48
el 08-21-2025 07:53 AM
013833: *Aug 20 23:57:20: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013834: *Aug 21 00:05:22: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013835: *Aug 21 00:05:54: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
013836: *Aug 21 00:06:06: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
013837: *Aug 21 00:07:22: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013838: *Aug 21 00:08:19: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013839: *Aug 21 00:10:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013842: *Aug 21 00:20:48: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013843: *Aug 21 00:21:47: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013844: *Aug 21 00:27:55: %SW_MATM-4-MACFLAP_NOTIF: Host a425.1bc1.ee6a in vlan 132 is flapping between port Gi1/0/22 and port Gi1/0/20
013845: *Aug 21 00:30:50: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013846: *Aug 21 00:37:14: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013847: *Aug 21 00:40:15: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013848: *Aug 21 00:40:50: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013851: *Aug 21 00:51:52: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013852: *Aug 21 00:53:29: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013853: *Aug 21 00:57:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013854: *Aug 21 01:00:19: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013855: *Aug 21 01:01:34: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
013856: *Aug 21 01:14:36: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013857: *Aug 21 01:15:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013858: *Aug 21 01:15:51: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013859: *Aug 21 01:16:40: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013862: *Aug 21 01:20:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013863: *Aug 21 01:23:37: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013864: *Aug 21 01:25:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013865: *Aug 21 01:27:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013866: *Aug 21 01:28:10: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013867: *Aug 21 01:30:09: %SW_MATM-4-MACFLAP_NOTIF: Host a425.1bc1.ee6a in vlan 132 is flapping between port Gi1/0/22 and port Gi1/0/20
013868: *Aug 21 01:30:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013869: *Aug 21 01:30:54: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013870: *Aug 21 01:35:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013871: *Aug 21 01:40:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013874: *Aug 21 01:55:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013875: *Aug 21 01:56:48: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
013876: *Aug 21 01:59:32: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013877: *Aug 21 02:00:01: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013878: *Aug 21 02:00:47: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013879: *Aug 21 02:01:47: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
013880: *Aug 21 02:02:22: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
013881: *Aug 21 02:05:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013882: *Aug 21 02:06:04: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013883: *Aug 21 02:07:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013884: *Aug 21 02:17:41: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013887: *Aug 21 02:23:44: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013888: *Aug 21 02:29:32: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013889: *Aug 21 02:30:21: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013890: *Aug 21 02:35:55: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013891: *Aug 21 02:37:30: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013894: *Aug 21 02:50:45: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013895: *Aug 21 02:51:51: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013896: *Aug 21 02:52:32: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013897: *Aug 21 02:55:03: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013898: *Aug 21 03:04:33: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
013899: *Aug 21 03:07:50: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
013900: *Aug 21 03:08:10: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013901: *Aug 21 03:09:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013902: *Aug 21 03:10:15: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013903: *Aug 21 03:10:45: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013906: *Aug 21 03:20:14: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013907: *Aug 21 03:31:51: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
013908: *Aug 21 03:37:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013909: *Aug 21 03:38:15: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013910: *Aug 21 03:41:51: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013911: *Aug 21 03:43:07: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013913: *Aug 21 03:48:36: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013915: *Aug 21 03:51:51: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013916: *Aug 21 03:56:45: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013917: *Aug 21 04:00:09: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013918: *Aug 21 04:00:49: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013919: *Aug 21 04:04:21: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013920: *Aug 21 04:05:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013921: *Aug 21 04:06:09: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013922: *Aug 21 04:15:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013925: *Aug 21 04:20:09: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013926: *Aug 21 04:23:45: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013927: *Aug 21 04:25:13: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013928: *Aug 21 04:25:27: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013929: *Aug 21 04:30:56: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013930: *Aug 21 04:33:29: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013931: *Aug 21 04:34:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013932: *Aug 21 04:37:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013933: *Aug 21 04:37:38: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013934: *Aug 21 04:43:47: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
013936: *Aug 21 04:49:37: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013938: *Aug 21 04:50:48: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013939: *Aug 21 04:51:09: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013940: *Aug 21 04:51:41: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013941: *Aug 21 04:51:52: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013942: *Aug 21 04:52:39: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013943: *Aug 21 04:55:10: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013944: *Aug 21 04:59:38: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013945: *Aug 21 05:06:08: %SW_MATM-4-MACFLAP_NOTIF: Host a425.1bc1.ee6a in vlan 132 is flapping between port Gi1/0/22 and port Gi1/0/20
013946: *Aug 21 05:06:09: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013947: *Aug 21 05:07:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013948: *Aug 21 05:10:09: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013949: *Aug 21 05:10:28: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013950: *Aug 21 05:11:55: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
013951: *Aug 21 05:15:16: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013953: *Aug 21 05:19:56: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013955: *Aug 21 05:21:50: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013956: *Aug 21 05:23:10: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013957: *Aug 21 05:25:32: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013958: *Aug 21 05:30:10: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
013959: *Aug 21 05:35:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013960: *Aug 21 05:40:45: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013961: *Aug 21 05:45:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013964: *Aug 21 05:50:49: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013965: *Aug 21 05:54:38: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013966: *Aug 21 05:55:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013967: *Aug 21 06:00:05: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013968: *Aug 21 06:04:37: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013969: *Aug 21 06:05:19: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
013970: *Aug 21 06:07:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013971: *Aug 21 06:09:09: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
013972: *Aug 21 06:15:25: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013975: *Aug 21 06:20:11: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013976: *Aug 21 06:35:17: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013977: *Aug 21 06:35:29: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013978: *Aug 21 06:37:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013979: *Aug 21 06:40:13: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013980: *Aug 21 06:42:43: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013982: *Aug 21 06:49:33: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013984: *Aug 21 06:50:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013985: *Aug 21 07:00:21: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013986: *Aug 21 07:05:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013987: *Aug 21 07:07:50: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
013988: *Aug 21 07:10:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013989: *Aug 21 07:15:14: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013991: *Aug 21 07:19:35: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013993: *Aug 21 07:20:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013994: *Aug 21 07:20:53: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013995: *Aug 21 07:23:02: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013996: *Aug 21 07:27:50: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
013997: *Aug 21 07:30:15: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013998: *Aug 21 07:30:31: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
013999: *Aug 21 07:30:34: %SW_MATM-4-MACFLAP_NOTIF: Host a425.1bc1.ee6a in vlan 132 is flapping between port Gi1/0/22 and port Gi1/0/20
014000: *Aug 21 07:35:30: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014001: *Aug 21 07:44:37: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014004: *Aug 21 07:50:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014005: *Aug 21 07:52:23: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
014006: *Aug 21 08:00:21: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014007: *Aug 21 08:01:18: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014008: *Aug 21 08:01:52: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014009: *Aug 21 08:06:08: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014010: *Aug 21 08:06:13: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014011: *Aug 21 08:07:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014012: *Aug 21 08:07:38: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014013: *Aug 21 08:08:30: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014014: *Aug 21 08:10:49: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014015: *Aug 21 08:15:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014018: *Aug 21 08:21:05: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014019: *Aug 21 08:21:40: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014020: *Aug 21 08:21:49: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014021: *Aug 21 08:22:43: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014022: *Aug 21 08:23:03: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014023: *Aug 21 08:25:17: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014024: *Aug 21 08:25:30: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014025: *Aug 21 08:27:43: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014027: *Aug 21 08:30:55: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014028: *Aug 21 08:31:47: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014030: *Aug 21 08:35:18: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014031: *Aug 21 08:36:18: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014032: *Aug 21 08:37:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014033: *Aug 21 08:38:16: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014034: *Aug 21 08:39:10: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014035: *Aug 21 08:40:18: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014036: *Aug 21 08:40:58: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014037: *Aug 21 08:41:45: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014038: *Aug 21 08:43:04: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014041: *Aug 21 08:51:04: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
014042: *Aug 21 08:52:44: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014043: *Aug 21 08:55:49: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014044: *Aug 21 08:59:53: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014045: *Aug 21 09:00:20: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014046: *Aug 21 09:02:10: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014047: *Aug 21 09:05:30: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014048: *Aug 21 09:05:52: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014049: *Aug 21 09:06:09: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014050: *Aug 21 09:07:23: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014051: *Aug 21 09:08:18: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014052: *Aug 21 09:09:39: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014053: *Aug 21 09:10:10: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014054: *Aug 21 09:11:50: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014055: *Aug 21 09:12:04: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
014056: *Aug 21 09:12:26: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014057: *Aug 21 09:12:46: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014058: *Aug 21 09:15:08: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014059: *Aug 21 09:15:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014061: *Aug 21 09:18:39: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
014062: *Aug 21 09:19:38: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014064: *Aug 21 09:22:37: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014065: *Aug 21 09:25:07: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014066: *Aug 21 09:25:28: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
014067: *Aug 21 09:29:39: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014068: *Aug 21 09:30:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/20 and port Gi1/0/21
014069: *Aug 21 09:31:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014070: *Aug 21 09:35:36: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
014071: *Aug 21 09:35:48: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014072: *Aug 21 09:36:17: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014073: *Aug 21 09:37:39: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014074: *Aug 21 09:38:17: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014075: *Aug 21 09:40:22: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014076: *Aug 21 09:44:56: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014077: *Aug 21 09:47:53: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014080: *Aug 21 09:50:52: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014081: *Aug 21 09:51:51: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014082: *Aug 21 09:53:06: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014083: *Aug 21 09:54:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014084: *Aug 21 09:58:17: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014085: *Aug 21 10:06:09: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014086: *Aug 21 10:06:16: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014087: *Aug 21 10:09:19: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014088: *Aug 21 10:09:46: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014089: *Aug 21 10:11:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014090: *Aug 21 10:12:18: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014091: *Aug 21 10:12:51: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014092: *Aug 21 10:15:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014095: *Aug 21 10:20:35: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014096: *Aug 21 10:25:07: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014097: *Aug 21 10:25:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014098: *Aug 21 10:25:53: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014099: *Aug 21 10:28:19: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014100: *Aug 21 10:28:36: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
014101: *Aug 21 10:29:21: %SW_MATM-4-MACFLAP_NOTIF: Host 24d9.2149.39c5 in vlan 132 is flapping between port Gi1/0/21 and port Gi1/0/22
014102: *Aug 21 10:30:32: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014103: *Aug 21 10:35:34: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014104: *Aug 21 10:35:48: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014105: *Aug 21 10:36:02: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014106: *Aug 21 10:37:24: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014109: *Aug 21 10:38:04: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014110: *Aug 21 10:38:13: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014111: *Aug 21 10:38:36: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
014112: *Aug 21 10:38:47: %SW_MATM-4-MACFLAP_NOTIF: Host c018.0386.af9c in vlan 32 is flapping between port Gi1/0/21 and port Gi1/0/20
cm_tr_p2c_cabecera1_9300# sh clock
*10:40:09.165 SCL Thu Aug 21 2025
el 08-21-2025 09:07 AM
c018.0386.af9c <<- check this MAC in table of SW9200 1/2
It can ONE Server have two leg connect to both SW
el 08-21-2025 09:53 AM
cm_tr_p2c_cabecera1_9300#sh mac add add c018.0386.af9c
Mac Address Table
32 c018.0386.af9c DYNAMIC Gi1/0/21
Mac Address Table
32 c018.0386.af9c DYNAMIC Gi1/0/20
SW1_ACCESO_TR_P2C#sh mac add add c018.0386.af9c
Mac Address Table
32 c018.0386.af9c STATIC Gi1/0/25
SW1_ACCESO_TR_P2C#sh run int Gi1/0/25
Building configuration...
Current configuration : 260 bytes
interface GigabitEthernet1/0/25
description lan datos
switchport mode access
device-tracking attach-policy IPDT_POLICY
ip flow monitor IPv4_NETFLOW input
dot1x max-reauth-req 3
no macro auto processing
source template MAB
spanning-tree portfast
end
SW1_ACCESO_TR_P2C#sh mac add int Gi1/0/25
Mac Address Table
SW1_ACCESO_TR_P2C#
SW2_ACCESO_TR_P2C#sh mac add add c018.0386.af9c
Mac Address Table
SW3_ACCESO_TR_P2C#sh mac add add c018.0386.af9c
Mac Address Table
32 c018.0386.af9c DYNAMIC Gi1/0/47
Gig 1/0/47 124 R S I C9300-24T Gig 1/0/22
Gig 1/0/48 152 R S I C9300-24T Gig 1/0/22
SW3_ACCESO_TR_P2C#
el 08-21-2025 10:31 AM
SW1_ACCESO_TR_P2C#sh run int Gi1/0/25 <<- what device connect to this port?
MHM
el 08-21-2025 10:49 AM
There is only one HP computer connected.
SW1_ACCESO_TR_P2C#sh mac add int GigabitEthernet1/0/25
Mac Address Table
SW1_ACCESO_TR_P2C#sh run int GigabitEthernet1/0/25
source template MAB
end
SW1_ACCESO_TR_P2C#sh cdp nei GigabitEthernet1/0/25
Total cdp entries displayed : 0
SW1_ACCESO_TR_P2C#
08-24-2025 01:39 PM - editado 08-24-2025 04:31 PM
Did you verify that all the switch were using the same STP(RSTP or rapid-pvst)?
Could you share the "show spanning-tree summary" of the access router too?
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
