em 12-12-2018 04:24 AM
Dear all
I've had some issues with my IP phones during the calls. It has shown me on the Phone's display "Network down" and getting mute in the middle of the calls.
I checked the logs on the access switches (C2960X) and appeared logs of interfaces like:
Dec 11 18:41:44 MET: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/42: PD removed
Dec 11 18:45:22 MET: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/42: Power granted
Dec 11 20:30:07 MET: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/39: PD removed
My IP phones are Grandstream GXP1625;
My access switches are C2960-X and are running into version 15.2(4)E2;
Below some outputs of one interface has been crashed:
switch# sh power inline GigabitEthernet 1/0/19
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/19 auto on 13.0 Ieee PD 2 30.0
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
Gi1/0/19 30.0 15.4
switch#test cable-diagnostics tdr interface Gi1/0/19
TDR test started on interface Gi1/0/19
A TDR test can take a few seconds to run on an interface
Use 'show cable-diagnostics tdr' to read the TDR results.
switch#sh cable-diagnostics tdr interface Gi1/0/19
TDR test last run on: December 12 12:52:44
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/19 1000M Pair A 55 +/- 10 meters Pair B Normal
Pair B 55 +/- 10 meters Pair A Normal
Pair C 55 +/- 10 meters Pair D Normal
Pair D 55 +/- 10 meters Pair C Normal
switch#sh logging | i Gi1/0/19
Dec 7 23:29:12 MET: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/19: Power granted
Dec 11 18:22:32 MET: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/19: PD removed
Dec 11 18:25:01 MET: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/19: Power granted
em 01-05-2019 12:38 AM
Hi....
Could you provide the interface configuration from your switch?
Did you try with another phone or this problem occurs with all of them?
Try to connect your phone in another interface to verify if this problem occurs in another port.
regards,
Fulvio
em 01-07-2019 02:45 AM
em 01-07-2019 03:36 AM
Navegue pelos links rápidos da Comunidade e usufrua de um conteúdo personalizado e em seu idioma nativo:
