cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Catalyst 8200 and 8300 DRAM Upgrade
wjuliao
I need to upgrade DRAM for several Catalyst models from 8G to 16G but wondering if I can simply add another 8G module or if I need to remove the existent 8G module and add a 16G module. How many slots are on those boxes?
Router model From TO
C8200-1N-4T 8GB DRAM 16 GB DRAM
C8300-1N1S-6T 8GB DRAM 16 GB DRAM
C8300-2N2S-6T 8GB DRAM 16 GB DRAM
C8300-1N1S-4T2X 8GB DRAM 16 GB DRAM
C8300-2N2S-4T2X 8GB DRAM 16 GB DRAM
1 Soluções Aceita
Soluções aceites
@wjuliao
This should be replacement as you have one slots for Removable M.2 card. If you have only one slot, you dont have much alternative but replace the current 8GB to 16GB.
 And you need to check which card do you have or intend to buy.
• DRAM options
• 1x 16GB DDR4 (upgrade)
• 1x 32GB DDR4 (upgrade)
Ver solução na publicação original
2 RESPOSTAS 2
@wjuliao
• DRAM options
wjuliao
Hi Flavio,
Yes, that was exactly my question, if just one slot is available. In fact I have now found this information at one FAQ for the 8200. Thanks for the hint.
Catalyst 8200 Series Edge Platforms FAQ - Cisco
Note:         A single Dual Inline Memory Module (DIMM) configuration is supported. The upgrade options available are 1x 8GB, 1x 16GB and 1x 32GB.
