em 10-18-2024 10:18 AM
I'm trying to downgrade to a version recommended by Cisco:
from version 7.9.2
for version: 7.7.21
I installed the necessary packages that go to the repository and are inactive. When trying to activate them to install the ISO ncs540-mini-x-7.7.21.iso I encounter the following errors:
This error appears in all packages that are in the repository and I try to install
from version 7.9.2 (factory version)
for version: 7.7.21 (version recommended)
I installed the necessary packages that go to the repository and are inactive. When trying to activate them to install the ISO ncs540-mini-x-7.7.21.iso I encounter some errors: For example:
RP/0/RP0/CPU0:cisco#install activate ncs540-mpls-te-rsvp-1.0.0.0-r7721.x86_64
Fri Oct 18 13:56:33.722 -03
2024-10-18 13:56:35 Install operation 119 started by root:
install activate pkg ncs540-mpls-te-rsvp-1.0.0.0-r7721.x86_64
2024-10-18 13:56:36 Package list:
2024-10-18 13:56:36 ncs540-mpls-te-rsvp-1.0.0.0-r7721.x86_64
2024-10-18 13:56:58 Install operation 119 aborted
RP/0/RP0/CPU0:dc-borda-2#show install log 119
Fri Oct 18 13:57:09.260 -03
2024-10-18 13:56:42 Action 1: install prepare action started
2024-10-18 13:56:56 ERROR: failed to determine package type for file 'ncs540-mpls-te-rsvp-1.0.0.0-r7721.x86_64'
2024-10-18 13:56:56 Action 1: install prepare action aborted
2024-10-18 13:56:56 ERROR!! failed while complete prepare checks on packages
2024-10-18 13:56:58 Ending operation 119
This error appears in all packages that are in the repository and I try to install (RPM).
INSTALL INACTIVE
RP/0/RP0/CPU0:cisco#show install inactive
Fri Oct 18 13:44:51.640 -03
11 inactive package(s) found:
ncs540-li-1.0.0.0-r7721
ncs540-isis-1.0.0.0-r7721
ncs540-ospf-1.0.0.0-r7721
ncs540-k9sec-1.0.0.0-r7721
ncs540-mcast-1.0.0.0-r7721
ncs540-mgbl-1.0.0.0-r7721
ncs540-mpls-1.0.0.0-r7721
ncs540-eigrp-1.0.0.0-r7721
ncs540-lictrl-1.0.0.0-r7721
INSTALL REPOSITORY
RP/0/RP0/CPU0:dc-borda-2#show install repository
Fri Oct 18 13:42:03.800 -03
22 package(s) in XR repository:
ncs540-mgbl-1.0.0.0-r792.x86_64
ncs540-ospf-1.0.0.0-r792.x86_64
ncs540-li-1.0.0.0-r792.x86_64
ncs540-mpls-1.0.0.0-r792.x86_64
ncs540-li-1.0.0.0-r7721.x86_64
ncs540-isis-1.0.0.0-r7721.x86_64
ncs540-isis-1.0.0.0-r792.x86_64
ncs540-ospf-1.0.0.0-r7721.x86_64
ncs540-xr-7.9.2
ncs540-k9sec-1.0.0.0-r792.x86_64
ncs540-k9sec-1.0.0.0-r7721.x86_64
ncs540-mcast-1.0.0.0-r7721.x86_64
ncs540-lictrl-1.0.0.0-r792.x86_64
ncs540-mgbl-1.0.0.0-r7721.x86_64
ncs540-mcast-1.0.0.0-r792.x86_64
ncs540-mpls-1.0.0.0-r7721.x86_64
ncs540-mpls-te-rsvp-1.0.0.0-r792.x86_64
ncs540-eigrp-1.0.0.0-r792.x86_64
ncs540-eigrp-1.0.0.0-r7721.x86_64
ncs540-lictrl-1.0.0.0-r7721.x86_64
MATRIX
RP/0/RP0/CPU0:cisco#show install upgrade-matrix iso /harddisk:/GO/ncs540-mini-x-7.7.21.iso from-running
Fri Oct 18 13:49:31.655 -03
This may take a while ...
Upgrade from the current software [7.9.2] to 7.7.21 is supported
From To Bridge SMUs Required Caveats / Comments
7.9.2 7.7.21 None None
INSTALL REPLACE
RP/0/RP0/CPU0:cisco#install replace ncs540-mini-x-7.7.21
Fri Oct 18 13:29:14.611 -03
2024-10-18 13:29:27 Install operation 116 started by root:
2024-10-18 13:29:27 install replace source ncs540-mini-x-7.7.21
2024-10-18 13:29:31 No install operation in progress at this moment
2024-10-18 13:29:31 Checking system is ready for install operation
2024-10-18 13:29:32 'install replace' in progress
2024-10-18 13:29:32 ERROR: Golden-ISO has to be used when 'replace' option is used
2024-10-18 13:29:32 Ending operation 116
2024-10-18 13:29:32 Install operation 116 aborted
P/0/RP0/CPU0:cisco#show install log 116
Fri Oct 18 13:29:44.881 -03
INSTALL ACTIVATE
RP/0/RP0/CPU0:cisco#install activate ncs540-mini-x-7.7.21
Fri Oct 18 13:30:17.427 -03
2024-10-18 13:30:31 Install operation 117 started by root:
2024-10-18 13:30:31 install activate pkg ncs540-mini-x-7.7.21
2024-10-18 13:30:35 No install operation in progress at this moment
2024-10-18 13:30:35 Checking system is ready for install operation
2024-10-18 13:30:36 'install activate' in progress
2024-10-18 13:30:36 ISO ncs540-mini-x-7.7.21 in input package list. Going to upgrade the system to version 7.7.21.
This install operation will reload the system, continue?
[yes:no]:[yes] yes
2024-10-18 13:30:54 Optimized list to prepare after sanitizing input list for superseded packages:
2024-10-18 13:30:54 Package list:
2024-10-18 13:30:54 ncs540-mini-x-7.7.21
2024-10-18 13:30:54 The operation is past point-of-no-return and can no longer be stopped!
2024-10-18 13:30:54 Action 1: install prepare action started
2024-10-18 13:30:54 Triggering prepare operation.
This may take a while...
2024-10-18 13:30:54 Error! The following package(s) is/are required to be activated as part of this operation:
2024-10-18 13:30:54 ncs540-k9sec
ncs540-mgbl
ncs540-lictrl
ncs540-mpls
ncs540-li
ncs540-mcast
ncs540-mpls-te-rsvp
ncs540-ospf
ncs540-eigrp
ncs540-isis
2024-10-18 13:30:59 Ending operation 117
2024-10-18 13:30:59 Install operation 117 aborted
RP/0/RP0/CPU0:cisco#show install log 117
Fri Oct 18 13:40:23.203 -03
ncs540-mgbl
ncs540-lictrl
ncs540-mpls
ncs540-li
ncs540-mcast
ncs540-mpls-te-rsvp
ncs540-ospf
ncs540-eigrp
ncs540-isis
Could you help me?
Erico
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
Navegue pelos links rápidos da Comunidade e usufrua de um conteúdo personalizado e em seu idioma nativo:
