cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
23
Respostas
Switch de acesso com tempo de resposta elevado
Luizhen
O nosso switch está com o tempo de resposta muito alto, creio que seja por causa da inundação de DHCP, ele fica gerando log diversos logs em pouquíssimos segundos, como este abaixo:
iaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0ee4.3cb5.5fdd
Aug 1 14:34:51: DHCP_SNOOPING: message type : DHCPDISCOVER DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0ee4.3cb5.5fdd
Aug 1 14:34:51: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (60)
Aug 1 14:34:51: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/10 for pak. Was not set
Aug 1 14:34:51: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/10
Aug 1 14:34:51: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/10)
Aug 1 14:34:51: DHCP_SNOOPING: process new DHCP packet, message type: DHCPREQUEST, input interface: Gi0/10, MAC da: ffff.ffff.ffff, MAC sa: 0ee4.3cb5.5fdd, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0ee4.3cb5.5fdd
Aug 1 14:34:51: DHCP_SNOOPING: message type : DHCPREQUEST DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0ee4.3cb5.5fdd
Aug 1 14:34:54: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/10 for pak. Was not set
Aug 1 14:34:54: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/10
Aug 1 14:34:54: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/10)
Aug 1 14:34:54: DHCP_SNOOPING: process new DHCP packet, message type: DHCPREQUEST, input interface: Gi0/10, MAC da: ffff.ffff.ffff, MAC sa: d08e.79e0.18bd, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: d08e.79e0.18bd
Aug 1 14:34:54: DHCP_SNOOPING: message type : DHCPREQUEST DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: d08e.79e0.18bd
Aug 1 14:34:54: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (10)
Aug 1 14:34:55: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/10 for pak. Was not set
Aug 1 14:34:55: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/10
Aug 1 14:34:55: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/10)
Aug 1 14:34:55: DHCP_SNOOPING: process new DHCP packet, message type: DHCPREQUEST, input interface: Gi0/10, MAC da: ffff.ffff.ffff, MAC sa: d08e.79e0.18bd, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: d08e.79e0.18bd
Aug 1 14:34:55: DHCP_SNOOPING: message type : DHCPREQUEST DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: d08e.79e0.18bd
Aug 1 14:34:55: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (10)
O que podemos fazer?
23 RESPOSTAS 23
SamuelGLN
Olá @Luizhen!
Caso a interface Gi0/10 esteja em trunk, ela está com ip dhcp snooping trust configurado? Portas de upstream para os servidores DHCP devem conter essa configuração.
Se não for esse o caso, poderia compartilhar em qual versão está o SW?
Best regards
******* If This Helps, Please Rate *******
Samuel, boa tarde!
Sim, é uma porta trunk e o switch é o: Modelo: WS-C2960CX-8PC-L Versão: 15.2(7)E7  Imagem: C2960CX-UNIVERSALK9-M
Segue configuração da porta:
interface GigabitEthernet0/10
description ## UL-35 ##
switchport trunk allowed vlan 5,6,10,44,50,52-54,60,70,90,110,120,130,301,1000
switchport trunk allowed vlan add 1010
switchport mode trunk
switchport nonegotiate
logging event trunk-status
load-interval 30
spanning-tree link-type point-to-point
Olá @Luizhen
 Como está o uso de CPU e memória do switch?
show  proc cpu
Flávio, boa tarde!
Segue o uso completo em txt., o resumo abaixo:
SW_CTJL_38#show proc cpu
CPU utilization for five seconds: 18%/0%; one minute: 18%; five minutes: 19%
no ip dhcp snooping information option
this need only
MHM
I did this, but the logs keep appearing.
You add it in Which SW?
I think you have one Access SW abd other core SW
Ypu need to add it in access SW
When you config dhcp snooping
MHM
I add it to the "Conf t" of switch 38 (which is the switch where the logs are being generated).
SW_CTJL_38#conf t
Enter configuration commands, one per line. End with CNTL/Z.
SW_CTJL_38(config)#
SW_CTJL_38(config)#no ip dhcp snooping information option
Host connect to this SW or other SW?
You need to add it to SW host connect to and config with dhcp snooping
MHM
The switch 38 is connected to switch 35, with the DHCP SNOOPING configuration on both.
no ip dhcp snooping information option <<- need to add to SW35 if host connect to this SW
Yes, i make this, but not resolved:
SW_CTJL_35#conf t
SW_CTJL_35(config)#no ip dhcp snooping information option
SW_CTJL_35(config)#
SW_CTJL_35#
SW_CTJL_38# conf t
SW_CTJL_38(config)#exi
The link interconnect both SW is config as trust or non trust?
MHM
Trust:
SW_CTJL_38#sh run int g0/10
Building configuration...
Current configuration : 339 bytes
load-interval 30
SW_CTJL_35#sh run int g1/0/24
Current configuration : 279 bytes
interface GigabitEthernet1/0/24
description ## DL-38 ##
switchport trunk allowed vlan 5,6,10,60,110,120,130,1010
load-interval 30
