annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Block a port ?
jmb09
I have a wifi acces point connect to a switch C2960X.
Often people unplug cable and connect its equipments in place of this wifi acces point !
I was considering to configure port-security on this port, but i'm afraid to block all wifi trafic ... Is somebody ha s solution ?
10 RÉPONSES 10
If this AP is local mode central SWITCHING' then you can use port-secuirty in port
If this AP is flexconn then you can not use port-secuirty
MHM
Thanks, i have severall ap of different model, this is a 1602I manage by a controler that is a 1832I
Is it possible with a port-security to shutdown the port if this AP is unplung ?
If it AP flex then  sorry you can not use port-secuirty' do yoh have ISE ? You can use ISE to auth AP.
MHM
jmb09
Hi!
No i haven't it but it seems to be interresting .....
jmb09
is there a way if a port is unplug to shudown the port and not activate it when cable is plug again, may be i was wrong by using port-security ?
only port-security can do that and hence AP is flex if you run port-secuirty it will drop traffic of wifi endpoint
MHM
jmb09
Ok i well udestand i will take a look with my resailer next year, it should come install new accex point ....
Thank you for your time and your patience have a nice day ....
@jmb09
 Port-security is an alternative in many scenarios. Do you have a Wireless Lan Controller or this is some kind of stand alone (Mobility express) Access Points?
jmb09
Hi !
Yes at this time i have mobility express available and running, it's managing have 18 access point.
Mobility express version is now old (8.5.140.0) and we will renew 7 accesspoint in january, i hope having another version ...
@jmb09
 For your scnerio, I dont believe you can justify ISE implementation, which should be the ideal for network security. But, If I were you I would take a close look on the  Auto Smartports feature available on your switch.
Auto Smartports Configuration Guide, Release 15.0(1)SE - Auto Smartports and Static Smartports Macros [Cisco Catalyst 3750-X Series Switches] - Cisco
With a bit of study and tests, you may  come up with something to protect the Access Point against arbitrary disconnection.
