annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
dot1q tunnel : how it works?
axelhauguel
Dear All
I have order a cogent Global Peer Exchange port to transport my network between two locations.
On dashboard, I can "request" a VLAN to cogent (cogent port is set up as trunk). My "LAN" VLAN is VLAN 50, and VLAN 50 is not available on cogent port.
So, I want to transport my VLAN 50 under "cogent VLAN". I'have concluded I must use dot1q tunnel function on my Cisco N9K FX.
I'have write some commands to set up the port on my side :
Cogent VLAN : 807 and 808
My LAN VLAN : 50 and 100
N9K-PAR-2(config)# int port-channel 800
N9K-PAR-2(config-if)#   description "GPE"
N9K-PAR-2(config-if)#   switchport mode dot1q-tunnel
N9K-PAR-2(config-if)#   switchport vlan mapping 50 dot1q-tunnel 807
N9K-PAR-2(config-if)#   switchport vlan mapping 100 dot1q-tunnel 808
N9K-PAR-2(config-if)# no shut
N9K-PAR-2(config-if)# exit
N9K-PAR-2(config)# sh int port-channel 800 vlan mapping
Interface Po800:
Original VLAN                      Translated VLAN
50                                        807
100                                       808
N9K-PAR-2(config)#
So far it looks like it's set up fine. But when I do a "show running-config", it does not see my two VLANs 807 / 808:
interface port-channel800
  description "GPE"
  switchport vlan mapping 50,100 dot1q-tunnel 807
  spanning-tree port type edge
N9K-PAR-2(config)#
In the running config, he see both lan on dot1q-tunnel 807. But.. that not I have set UP !
Is there another way to process or it's a bug ?
5 RÉPONSES 5
because it tunnel VLAN not VLAN assign to Access port.
Hi !
Happy to see you again !
mmh what do you understand by that please? I need to set what pvid ?
can you draw topology ?
I'have attached topology scheme in first post, "scheme.jpg"
