annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
[URGENT] NEED HELP L2VPN MPLS IOS XR
axelhauguel
Hi all,
I have 2 NCS-5501-SE router and I would like to configure MPLS to have L2VPN working, for a migration, tomorrow...
Currently, I have :
- OSPF configured in both sides, and it send /32 IP of loopback
- MPLS LDP neighbor seem UP
- L2VPN circuit is down
# Router TH2
interface Loopback0
 description "TH2 - MPLS"
 ipv4 address 45.13.119.156 255.255.255.255
interface HundredGigE0/0/1/3
 description "L2 : Telehouse 2 - DC2SCALE PAR2 [100G]"
interface HundredGigE0/0/1/3.200
 ipv4 address 100.100.0.0 255.255.255.254
 ipv6 nd suppress-ra
 encapsulation dot1q 200
interface HundredGigE0/0/1/3.998 l2transport
 encapsulation dot1q 998
router ospf DC2SCALE_PAR2
 router-id 45.13.119.156
 cost 200
 authentication message-digest
 mpls ldp auto-config
 redistribute connected
 area 1
  message-digest-key 1 md5 encrypted XXXX
l2vpn
 pw-class test1
  encapsulation mpls
   transport-mode ethernet
 xconnect group test
  p2p test
   neighbor ipv4 100.100.0.1 pw-id 999
    pw-class test1
mpls ldp
 address-family ipv4
=== Result ===
RP/0/RP0/CPU0:core01.th2#show mpls ldp neighbor
Sun Jan 28 10:05:51.046 UTC
Peer LDP Identifier: 45.13.119.157:0
  TCP connection: 45.13.119.157:51726 - 45.13.119.156:646
  Graceful Restart: No
  Session Holdtime: 180 sec
  State: Oper; Msgs sent/rcvd: 73/98; Downstream-Unsolicited
  Up time: 00:19:59
  LDP Discovery Sources:
    IPv4: (1)
    IPv6: (0)
  Addresses bound to this peer:
    IPv4: (39)
      2.57.253.87    37.49.238.14   45.13.119.1    45.13.119.129
      45.13.119.145  45.13.119.152  45.13.119.154  45.13.119.157
      45.13.119.161  45.13.119.193  45.13.119.225  45.13.119.241
      45.152.70.1    45.154.96.1    81.28.252.1    100.64.77.5
      100.64.78.5    100.64.84.6    100.64.85.6    100.64.86.6
      100.64.87.6    100.64.88.6    100.64.89.6    100.64.90.7
      100.64.91.6    100.64.92.6    100.64.93.6    100.64.94.6
      100.64.101.129  100.100.0.1    163.5.83.1     163.5.142.1
      163.5.160.0    185.171.202.1  193.105.29.19  193.105.29.21
      193.178.0.37   193.201.149.133  194.147.5.1
    IPv6: (0)
RP/0/RP0/CPU0:core01.th2#show l2vpn xconnect pw-id 999 detail
Sun Jan 28 10:06:11.096 UTC
Group test, XC test, state is down; Interworking none
  AC: HundredGigE0/0/1/3.998, state is up
    Type VLAN; Num Ranges: 1
    Rewrite Tags: []
    VLAN ranges: [998, 998]
    MTU 1504; XC ID 0x1; interworking none
    Statistics:
      packets: received 0, sent 0
      bytes: received 0, sent 0
      drops: illegal VLAN 0, illegal length 0
  PW: neighbor 100.100.0.1, PW ID 999, state is down ( provisioned )
    PW class test1, XC ID 0xc0000001
    Encapsulation MPLS, protocol LDP
    Source address 45.13.119.156
    PW type Ethernet, control word disabled, interworking none
    PW backup disable delay 0 sec
    Sequencing not set
    Ignore MTU mismatch: Disabled
    Transmit MTU zero: Disabled
    LSP : Down
    Load Balance Hashing: src-dst-ip
    PW Status TLV in use
      MPLS         Local                          Remote
      Label        24041                          unknown
      Group ID     0x8                            unknown
      Interface    HundredGigE0/0/1/3.998         unknown
      MTU          1504                           unknown
      Control word disabled                       unknown
      PW type      Ethernet                       unknown
      VCCV CV type 0x2                            0x0
                                                  (none)
                   (LSP ping verification)
      VCCV CC type 0x6                            0x0
                                                  (none)
                   (router alert label)
                   (TTL expiry)
    MIB cpwVcIndex: 3221225473
    Create time: 28/01/2024 09:55:25 (00:10:45 ago)
    Last time status changed: 28/01/2024 09:55:25 (00:10:45 ago)
    Statistics:
# Router Velizy1
interface Loopback0
 ipv4 address 45.13.119.157 255.255.255.255
interface Bundle-Ether2.999 l2transport
 encapsulation dot1q 101
interface Bundle-Ether2.200
 ipv4 address 100.100.0.1 255.255.255.254
 ipv6 nd suppress-ra
router ospf TH2
 router-id 45.13.119.158
 cost 200
 area 1
  route-policy RPL-DROP-DEFAULT-ROUTE in
l2vpn
xconnect group test
  p2p test
   neighbor ipv4 100.100.0.0 pw-id 999
    pw-class test1
mpls ldp
 router-id 45.13.119.157
 address-family ipv4
=== Result ===
RP/0/RP0/CPU0:core01.par2#show mpls ldp neighbor
Sun Jan 28 11:12:25.710 CET
Peer LDP Identifier: 45.13.119.156:0
  TCP connection: 45.13.119.156:646 - 45.13.119.157:51726
  State: Oper; Msgs sent/rcvd: 102/77; Downstream-Unsolicited
  Up time: 00:23:13
    IPv4: (1)
      Bundle-Ether2.200
    IPv6: (0)
    IPv4: (2)
      45.13.119.156  100.100.0.0
    IPv6: (0)
RP/0/RP0/CPU0:core01.par2#show l2vpn xconnect pw-id 999 detail
Sun Jan 28 11:12:38.651 CET
  AC: Bundle-Ether2.999, state is up
    Rewrite Tags: []
    VLAN ranges: [101, 101]
    MTU 1504; XC ID 0xa0000003; interworking none
    Statistics:
      packets: received 2205, sent 0
      bytes: received 171148, sent 0
  PW: neighbor 100.100.0.0, PW ID 999, state is down ( provisioned )
    PW class test1, XC ID 0xc0000002
    Source address 45.13.119.157
    Sequencing not set
    LSP : Down
      MPLS         Local                          Remote
      Label        24032                          unknown
      Group ID     0x20008014                     unknown
      Interface    Bundle-Ether2.999              unknown
      MTU          1504                           unknown
                                                  (none)
                                                  (none)
                   (TTL expiry)
    MIB cpwVcIndex: 3221225474
    Create time: 28/01/2024 10:58:52 (00:13:46 ago)
    Last time status changed: 28/01/2024 10:58:52 (00:13:46 ago)
    Statistics:
      packets: received 0, sent 2205
      bytes: received 0, sent 171148
Anyone can help me to have this working quickly please?
Thank you and really appreciated! I'm probably missing something
3 RÉPONSES 3
axelhauguel
bad ip using in xconnect neighbor.
I am going to bed again
Bonjour @axelhauguel
Plus de soucis alors ?
Best regards
Jerems
Effectivement le LSP Down indiquait que le path MPLS comportait un souci.
LSP : Down
