le 07-12-2021 02:33 PM - dernière modification le 14-12-2021 02:29 PM par Jimena Saez
Salut,
Nous sommes confrontés à un problème de processeur avec un périphérique Cisco (agissant comme un périphérique principal) qui atteint souvent environ ~90%. Vous trouverez ci-dessous des détails concernant l'appareil lui-même :
Message d'origine:
We're facing a CPU issue with a cisco device (acting as a core device) which reaches often ~90%. Below are details regarding the device itself:
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 10-Sep-09 21:16 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD3, RELEASE SOFTWARE (fc3)
uptime is 3 years, 41 weeks, 2 days, 1 hour, 52 minutes
Uptime for this control processor is 3 years, 41 weeks, 2 days, 1 hour, 48 minutes
System returned to ROM by power cycle at 17:32:39 UTC Thu Apr 21 2011 (SP by power on)
System restarted at 20:15:38 UTC Thu Feb 22 2018
System image file is "disk0:/c7600s72033-advipservicesk9-mz.122-33.SRD3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7606-S (R7000) processor (revision 1.1) with 458720K/65536K bytes of memory.
Processor board ID FXS1651Q1Q7
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
43 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Et ci-dessous se trouvent les CPU logs signalés par l'appareil
Message d'origine:
And below are the CPU logs reported by the device:
Dec 7 14:30:05 : [syslog@9 s_tc="770536"]: Dec 7 14:30:04.016 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 79%/75%, Top 3 processes(Pid/Util): 65/2%, 199/0%, 333/0%
Dec 7 14:58:44 : [syslog@9 s_tc="770759"]: Dec 7 14:58:43.908 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 65%/63%.
Dec 7 14:59:20 : [syslog@9 s_tc="770760"]: Dec 7 14:59:18.972 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/74%, Top 3 processes(Pid/Util): 435/1%, 199/0%, 250/0%
Dec 7 15:16:47 : [syslog@9 s_tc="770761"]: Dec 7 15:16:46.081 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 63%/62%.
Dec 7 15:17:12 : [syslog@9 s_tc="770762"]: Dec 7 15:17:11.653 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 91%/74%, Top 3 processes(Pid/Util): 521/6%, 520/6%, 7/2%
Dec 7 15:22:18 : [syslog@9 s_tc="770763"]: Dec 7 15:22:17.284 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 15:22:28 : [syslog@9 s_tc="770764"]: Dec 7 15:22:27.304 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/75%, Top 3 processes(Pid/Util): 199/0%, 2/0%, 518/0%
Dec 7 15:24:48 : [syslog@9 s_tc="770765"]: Dec 7 15:24:47.569 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 64%/62%.
Dec 7 15:25:13 : [syslog@9 s_tc="770766"]: Dec 7 15:25:12.629 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/70%, Top 3 processes(Pid/Util): 7/1%, 435/1%, 199/0%
Dec 7 15:25:28 : [syslog@9 s_tc="770767"]: Dec 7 15:25:27.706 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 15:25:53 : [syslog@9 s_tc="770768"]: Dec 7 15:25:52.758 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/73%, Top 3 processes(Pid/Util): 7/2%, 435/0%, 199/0%
Dec 7 15:26:23 : [syslog@9 s_tc="770769"]: Dec 7 15:26:22.838 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 15:28:49 : [syslog@9 s_tc="770770"]: Dec 7 15:28:48.031 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/72%, Top 3 processes(Pid/Util): 7/2%, 55/0%, 199/0%
Dec 7 15:32:34 : [syslog@9 s_tc="770771"]: Dec 7 15:32:33.549 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 15:36:19 : [syslog@9 s_tc="770772"]: Dec 7 15:36:18.910 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/72%, Top 3 processes(Pid/Util): 435/0%, 199/0%, 494/0%
Dec 7 15:36:29 : [syslog@9 s_tc="770773"]: Dec 7 15:36:28.962 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 15:39:00 : [syslog@9 s_tc="770774"]: Dec 7 15:38:59.207 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/72%, Top 3 processes(Pid/Util): 7/2%, 435/0%, 199/0%
Dec 7 15:39:15 : [syslog@9 s_tc="770775"]: Dec 7 15:39:14.263 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 64%/63%.
Dec 7 15:39:30 : [syslog@9 s_tc="770776"]: Dec 7 15:39:29.296 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/72%, Top 3 processes(Pid/Util): 506/2%, 435/0%, 7/0%
Dec 7 15:39:45 : [syslog@9 s_tc="770777"]: Dec 7 15:39:44.380 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 60%/59%.
Dec 7 15:43:40 : [syslog@9 s_tc="770778"]: Dec 7 15:43:39.685 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/74%, Top 3 processes(Pid/Util): 435/0%, 333/0%, 199/0%
Dec 7 15:44:35 : [syslog@9 s_tc="770779"]: Dec 7 15:44:34.793 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 15:46:05 : [syslog@9 s_tc="770780"]: Dec 7 15:46:04.914 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/74%, Top 3 processes(Pid/Util): 199/0%, 515/0%, 494/0%
Dec 7 15:46:21 : [syslog@9 s_tc="770781"]: Dec 7 15:46:19.970 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 64%/61%.
Dec 7 15:47:11 : [syslog@9 s_tc="770782"]: Dec 7 15:47:10.059 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/73%, Top 3 processes(Pid/Util): 435/1%, 199/0%, 333/0%
Dec 7 15:47:21 : [syslog@9 s_tc="770783"]: Dec 7 15:47:20.107 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 15:48:41 : [syslog@9 s_tc="770784"]: Dec 7 15:48:40.243 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/70%, Top 3 processes(Pid/Util): 7/3%, 435/0%, 199/0%
Dec 7 15:48:56 : [syslog@9 s_tc="770785"]: Dec 7 15:48:55.315 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 15:51:41 : [syslog@9 s_tc="770786"]: Dec 7 15:51:40.572 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/68%, Top 3 processes(Pid/Util): 7/3%, 435/1%, 506/0%
Dec 7 15:51:56 : [syslog@9 s_tc="770787"]: Dec 7 15:51:55.624 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 65%/60%.
Dec 7 15:53:06 : [syslog@9 s_tc="770788"]: Dec 7 15:53:05.737 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/74%, Top 3 processes(Pid/Util): 515/0%, 199/0%, 25/0%
Dec 7 15:53:36 : [syslog@9 s_tc="770789"]: Dec 7 15:53:35.837 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 65%/64%.
Dec 7 15:56:42 : [syslog@9 s_tc="770790"]: Dec 7 15:56:41.134 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/69%, Top 3 processes(Pid/Util): 7/2%, 199/0%, 435/0%
Dec 7 15:57:27 : [syslog@9 s_tc="770791"]: Dec 7 15:57:26.235 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 56%/56%.
Dec 7 15:59:22 : [syslog@9 s_tc="770792"]: Dec 7 15:59:21.388 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/75%, Top 3 processes(Pid/Util): 435/0%, 333/0%, 199/0%
Dec 7 16:00:27 : [syslog@9 s_tc="770793"]: Dec 7 16:00:26.544 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 58%/57%.
Dec 7 16:02:47 : [syslog@9 s_tc="770794"]: Dec 7 16:02:46.737 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/72%, Top 3 processes(Pid/Util): 7/2%, 518/0%, 499/0%
Dec 7 16:03:07 : [syslog@9 s_tc="770795"]: Dec 7 16:03:06.801 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 62%/61%.
Dec 7 16:10:27 : [syslog@9 s_tc="770803"]: Dec 7 16:10:27.376 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 90%/74%, Top 3 processes(Pid/Util): 520/5%, 7/1%, 270/1%
Dec 7 16:11:03 : [syslog@9 s_tc="770827"]: Dec 7 16:11:02.488 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 16:15:28 : [syslog@9 s_tc="770828"]: Dec 7 16:15:27.826 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/75%, Top 3 processes(Pid/Util): 199/0%, 25/0%, 499/0%
Dec 7 16:15:48 : [syslog@9 s_tc="770829"]: Dec 7 16:15:47.890 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 59%/58%.
Dec 7 16:16:14 : [syslog@9 s_tc="770830"]: Dec 7 16:16:13.006 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/71%, Top 3 processes(Pid/Util): 435/1%, 7/0%, 199/0%
Dec 7 16:16:24 : [syslog@9 s_tc="770831"]: Dec 7 16:16:23.054 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 62%/59%.
Dec 7 16:20:44 : [syslog@9 s_tc="770832"]: Dec 7 16:20:43.424 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/72%, Top 3 processes(Pid/Util): 7/1%, 435/0%, 199/0%
Dec 7 16:20:59 : [syslog@9 s_tc="770833"]: Dec 7 16:20:58.484 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 63%/60%.
Dec 7 16:23:14 : [syslog@9 s_tc="770834"]: Dec 7 16:23:13.709 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
Dec 7 16:23:24 : [syslog@9 s_tc="770835"]: Dec 7 16:23:23.741 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 62%/60%.
Dec 7 16:33:00 : [syslog@9 s_tc="770836"]: Dec 7 16:32:59.665 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/64%, Top 3 processes(Pid/Util): 521/8%, 506/1%, 199/0%
Dec 7 16:33:15 : [syslog@9 s_tc="770837"]: Dec 7 16:33:14.721 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 54%/52%.
Dec 7 16:33:30 : [syslog@9 s_tc="770838"]: Dec 7 16:33:29.741 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 85%/70%, Top 3 processes(Pid/Util): 521/12%, 435/1%, 199/0%
Dec 7 16:36:11 : [syslog@9 s_tc="770839"]: Dec 7 16:36:10.223 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 65%/58%.
Dec 7 16:51:12 : [syslog@9 s_tc="770840"]: Dec 7 16:51:11.421 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/70%, Top 3 processes(Pid/Util): 7/3%, 199/0%, 435/0%
Dec 7 16:54:37 : [syslog@9 s_tc="770841"]: Dec 7 16:54:36.703 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 55%/53%.
Dec 7 16:56:47 : [syslog@9 s_tc="770842"]: Dec 7 16:56:46.852 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 80%/61%, Top 3 processes(Pid/Util): 520/17%, 199/0%, 518/0%
Dec 7 16:56:57 : [syslog@9 s_tc="770843"]: Dec 7 16:56:56.880 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 52%/50%.
Dec 7 19:36:13 : [syslog@9 s_tc="770844"]: Dec 7 19:36:12.140 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/74%, Top 3 processes(Pid/Util): 435/0%, 199/0%, 333/0%
Dec 7 19:42:18 : [syslog@9 s_tc="770845"]: Dec 7 19:42:17.571 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 20:11:35 : [syslog@9 s_tc="770846"]: Dec 7 20:11:34.562 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/73%, Top 3 processes(Pid/Util): 435/1%, 7/0%, 199/0%
Dec 7 20:11:45 : [syslog@9 s_tc="770847"]: Dec 7 20:11:44.618 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 20:21:31 : [syslog@9 s_tc="770848"]: Dec 7 20:21:30.385 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 76%/70%, Top 3 processes(Pid/Util): 7/3%, 506/1%, 199/0%
Dec 7 20:22:06 : [syslog@9 s_tc="770849"]: Dec 7 20:22:05.442 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 20:30:42 : [syslog@9 s_tc="770850"]: Dec 7 20:30:41.125 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 79%/72%, Top 3 processes(Pid/Util): 7/4%, 333/0%, 518/0%
Dec 7 20:30:52 : [syslog@9 s_tc="770851"]: Dec 7 20:30:51.181 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 20:33:37 : [syslog@9 s_tc="770852"]: Dec 7 20:33:36.474 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 78%/74%, Top 3 processes(Pid/Util): 7/2%, 199/0%, 435/0%
Dec 7 20:34:12 : [syslog@9 s_tc="770853"]: Dec 7 20:34:11.570 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 20:40:38 : [syslog@9 s_tc="770854"]: Dec 7 20:40:37.109 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/74%, Top 3 processes(Pid/Util): 518/0%, 199/0%, 494/0%
Dec 7 20:40:48 : [syslog@9 s_tc="770855"]: Dec 7 20:40:47.161 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 61%/60%.
Dec 7 20:41:13 : [syslog@9 s_tc="770856"]: Dec 7 20:41:12.193 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 77%/69%, Top 3 processes(Pid/Util): 7/3%, 55/0%, 435/0%
Dec 7 20:42:08 : [syslog@9 s_tc="770857"]: Dec 7 20:42:07.329 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 20:45:13 : [syslog@9 s_tc="770858"]: Dec 7 20:45:12.562 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 81%/74%, Top 3 processes(Pid/Util): 7/3%, 435/0%, 55/0%
Dec 7 20:45:28 : [syslog@9 s_tc="770859"]: Dec 7 20:45:27.611 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 20:45:43 : [syslog@9 s_tc="770860"]: Dec 7 20:45:42.643 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/72%, Top 3 processes(Pid/Util): 199/0%, 435/0%, 333/0%
Dec 7 20:46:18 : [syslog@9 s_tc="770861"]: Dec 7 20:46:17.719 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
Dec 7 20:49:44 : [syslog@9 s_tc="770862"]: Dec 7 20:49:42.996 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 78%/75%, Top 3 processes(Pid/Util): 435/1%, 199/0%, 25/0%
Dec 7 20:52:29 : [syslog@9 s_tc="770863"]: Dec 7 20:52:28.353 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 65%/65%.
Dec 7 20:52:44 : [syslog@9 s_tc="770864"]: Dec 7 20:52:43.381 UTC: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Uti
lization(Total/Intr): 75%/73%, Top 3 processes(Pid/Util): 435/1%, 333/0%, 499/0%
Dec 7 20:58:20 : [syslog@9 s_tc="770904"]: Dec 7 20:58:19.635 UTC: %SYS-1-CPUFALLINGTHRESHOLD: Threshold: Total CPU Ut
ilization(Total/Intr) 26%/18%.
#sh processes cpu sorted | ex 0.00
CPU utilization for five seconds: 2%/1%; one minute: 4%; five minutes: 4%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
521 1928 3456 557 0.47% 0.03% 0.03% 2 SSH Process
333 192855844 59792130 3225 0.31% 0.16% 0.14% 0 HIDDEN VLAN Proc
506 105460116 235508094 447 0.23% 0.07% 0.08% 0 SNMP ENGINE
199 3349311564110075304 0 0.15% 0.16% 0.25% 0 IP Input
499 27279628 637727026 42 0.07% 0.03% 0.02% 0 BGP I/O
Je ne vois pas vraiment quel processus est à l'origine de ce problème de CPU, pourriez-vous m'aider s'il vous plaît ? La mise à niveau du système d'exploitation est-elle recommandée dans une telle situation ?
Message d'origine:
I can't really see which process is causing this CPU issue, could you please help with this? Is the OS upgrade recommended in such a situation?
14-12-2021 07:47 PM - modifié 14-12-2021 07:54 PM
Hello zizou6500,
Ces problèmes de CPU peuvent parfois être délicats. Pour répondre à un problème général de CPU, il faut être capable de déterminer quels paquets vont au CPU et si ces paquets sont censés être vus dans le processeur ou non.
Des paquets ne peuvent pas être directement transmis par CEF et doivent être traités plus en détail. Cela se fait par une inspection rapide lors des décisions d'expédition. Si un paquet répond à des critères tels que les suivants, il est marqué pour un traitement ultérieur et envoyé ou « donné » à la CPU du commutateur pour la commutation de processus : Pardon c´est en anglais ☺️
ARP requests and replies
IP packets requiring a response from a router (TTL has expired, maximum transmission unit [MTU] is exceeded, fragmentation is needed, and so on)
IP broadcasts that will be relayed as unicast (Dynamic Host Configuration Protocol [DHCP] requests, IP helper-address functions)
Routing protocol updates
Cisco Discovery Protocol (CDP) packets
Packets needing encryption
Packets triggering Network Address Translation (NAT)
Legacy multiprotocol packets (IPX, AppleTalk, and so on)
Packets destined to the switch à this is not exception
Packets with options
No route in the HW CEF
Resources full (tcam , template)
SW-supported feature ( nbar, GRE) or feature exception
ACL log
Multicast path setupMulticast RPF dropspackets punted to generate ICMP redirects)
Tu peux utiliser ce guide communautaire , encore en anglais pour pouvoir investiguer sur ce problème de CPU .
Aussi tu dois considerer le résultat de cette commande et prendre en consideration le principal contrevenant ( le processus qui consomme le plus de CPU)
Verifier si il y a un bug qui se rapporte a ce processus là selon la version d´ IOS que tu utilises .
J´éspère avoir pu t´aider .
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
Parcourez les liens directs de la Communauté et profitez de contenus personnalisés en français
