annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Make Wake on lan with Catalyst 2960 CX
Arnauda
Could you explain me how make the Wake on Lan.
I've got 3 PC on switch with a vlan 240.
PC1 => 10.0.24.2
PC2 => 10.0.24.3
PC3 => 10.0.24.10
I've enabled the options on Bios and same thing to network card for each PC.
I would like send a Magic packet from PC3 to PC1 and PC2.
Could you please describ all commands on the switch so that the wake on lan works?
Thanks in adavnce for your feedback.
regards.
3 RÉPONSES 3
 If they are on the same vlan it should work. Whats wrong?
M02@rt37
Hello @Arnauda,
Since the PCs are in the same VLAN (id 240), no need extra config for WoL.
Best regards
