le 23-02-2023 10:20 AM
Hello community,
Could anyone walk me step by step through telneting the router via console cable and pc.
I need to add this configuration on the below interface.
interface GigabitEthernet0/0/0
description WAN
ip address x.x.x.x x.x.x.x
access-list 30 remark ACCESS
access-list 30 permit x.x.x.x
line vty 0 4
access-class 30 in
transport input telnet ssh
transport output telnet ssh
Thank you for your help. Br,
Résolu ! Accéder à la solution.
le 23-02-2023 11:45 AM
NOTE:-
always remember your username/password for login
always remember your enable password
23-02-2023 10:53 AM - modifié 23-02-2023 10:53 AM
Your config is OK, but using console cable I dont think this will work
you need normal utp cable.
le 23-02-2023 11:35 AM
a serial/rj45 console cisco cable wont work ?
le 23-02-2023 11:41 AM
NO using console cable meaning using console port and meaning using
line console 0
using utp cable meaning using ethernet and meaning using
line vty
here you hav two option using telnet or ssh
le 23-02-2023 11:55 AM
once I connect my pc to the router I'll use putty but using what connection type? Thanks.
NOTE:-
Parcourez les liens directs de la Communauté et profitez de contenus personnalisés en français
