le 22-07-2019 05:40 AM
Bonjour,
est-ce mon module XFP qui est défaillant ?
j'utilise un chassis 7606 avec SPA-1X10GE-L-V2 et module XFP-10GLR-OC192SR.
On a déjà nettoyé notre XFP, mais reste toujours à la valeur -18.4
pourtant côté fournisseur ci-dessous les valeurs sur leur équipement :
- Rx Power: -3.59dBm
- Tx Power: -2.87dBm
Merci de votre aide.
Cdlt,
le 23-07-2019 12:25 PM
le 23-07-2019 11:05 PM
Bonjour,
#sh int te4/0/0
TenGigabitEthernet4/0/0 is up, line protocol is up (connected)
Hardware is TenGigEther SPA, address is 0014.695a.b200 (bia 0014.695a.b200)
Description: 10G secondary
MTU 9000 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not supported
Full-duplex, 10Gb/s
Transport mode LAN (10GBASE-R, 10.3125Gb/s)
input flow-control is on, output flow-control is on
Clock mode is auto
Last input 1d17h, output 00:00:01, output hang never
Last clearing of "show interface" counters 1d14h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
45572 packets output, 3000432 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
#sh log | inc 4/0/0
Jul 24 09:04:04.630 UTC: %LINK-3-UPDOWN: Interface TenGigabitEthernet4/0/0, changed state to down
Jul 24 09:04:04.590 UTC: %ETH_SPA_MAC-DFC4-6-INTR_BURST: Interrupts from MAC have crossed burst limit of 10 in 1000 msec for port 4/0/0
Jul 24 09:04:06.702 UTC: %ETH_SPA_MAC-DFC4-6-INTR_BURST: Interrupts from MAC have crossed burst limit of 10 in 1000 msec for port 4/0/0
Jul 24 09:04:08.814 UTC: %ETH_SPA_MAC-DFC4-6-INTR_BURST: Interrupts from MAC have crossed burst limit of 10 in 1000 msec for port 4/0/0
.Jul 24 09:04:11.474 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet4/0/0, changed state to up
.Jul 24 09:04:11.478 UTC: %LINK-3-UPDOWN: Interface TenGigabitEthernet4/0/0, changed state to up
Jul 24 09:04:10.926 UTC: %ETH_SPA_MAC-DFC4-6-INTR_BURST: Interrupts from MAC have crossed burst limit of 10 in 1000 msec for port 4/0/0
Jul 24 09:04:13.038 UTC: %ETH_SPA_MAC-DFC4-6-INTR_BURST: Interrupts from MAC have crossed burst limit of 10 in 1000 msec for port 4/0/0
Jul 24 09:04:15.150 UTC: %ETH_SPA_MAC-DFC4-6-INTR_BURST: Interrupts from MAC have crossed burst limit of 10 in 1000 msec for port 4/0/0
Jul 24 09:04:17.274 UTC: %ETH_SPA_MAC-DFC4-6-INTR_BURST: Interrupts from MAC have crossed burst limit of 10 in 1000 msec for port 4/0/0
Cdlt,
le 24-07-2019 12:01 PM
Bonjour,
Merci de partager l'information. Selon les logs il semble que le module est défectueux. pouvez-vous partager les informations suivantes
show module
sh run int Te4/0/0
show adjacency tenGigabitEthernet 4/0/0 detail
Je vous recommande également de réinsérer le module.
Cordialement,
Gary Bolivar,
le 25-07-2019 06:01 AM
Bonjour,
##sh run int te4/0/
Building configuration...
Current configuration : 137 bytes
interface TenGigabitEthernet4/0/0
description vers xx
mtu 9000
no ip address
no mls qos trust
no cdp enable
end
# show adjacency tenGigabitEthernet 4/0/0 detail
Protocol Interface Address
#sh module
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1019MP54
2 0 4-subslot SPA Interface Processor-400 7600-SIP-400 JAE14430MWJ
4 1 1-subslot SPA Interface Processor-600 7600-SIP-600 JAB1029025U
5 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL150567FK
6 2 Route Switch Processor 720 (Active) RSP720-3CXL-GE SAL1647STUH
Mod MAC addresses Hw Fw Sw Status
1 0017.59f4.d2c0 to 0017.59f4.d2ef 2.3 12.2(18r)S 15.3(3)S PwrDown
2 588d.09fa.3140 to 588d.09fa.31bf 2.7 15.3(3)S4 15.3(3)S4 Ok
4 001a.6d7f.4b00 to 001a.6d7f.4b3f 1.1 12.2(18r)SX 15.3(3)S Ok
5 503d.e56f.5b20 to 503d.e56f.5b37 5.0 12.2(18r)S 15.3(3)S Ok
6 5057.a8b9.8378 to 5057.a8b9.837b 5.13 12.2(33r)SR 15.3(3)S Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL1009ESN7 2.0 PwrDown
2/0 5xGE SPA SPA-5X1GE-V2 JAE1212BQK6 1.2 Ok
2/1 5xGE SPA SPA-5X1GE-V2 JAE14190APF 1.2 Ok
2/3 2xOC3 POS SPA SPA-2XOC3-POS JAB10230A8F 1.0 Ok
4 SIP-600 Distributed Forward 7600-SIP-600-DC JAB104500UQ 1.0 Ok
4/0 1x10GE XFP SPA SPA-1X10GE-L-V2 SAL16117GXV 1.3 Ok
5 Distributed Forwarding Card WS-F6700-DFC3CXL SAL1213KB0U 1.1 Ok
6 Policy Feature Card 3 7600-PFC3CXL SAL1647SSMQ 1.1 Ok
6 C7600 MSFC4 Daughterboard 7600-MSFC4 SAL1647SSJ9 5.0 Ok
Mod Online Diag Status
1 Not Applicable
2 Pass
2/0 Pass
2/1 Pass
2/3 Pass
4 Pass
4/0 Pass
5 Pass
6 Pass
Cdlt,
le 01-08-2019 04:41 PM
Parcourez les liens directs de la Communauté et profitez de contenus personnalisés en français
