How to set up duo mobile on Instagram
kimthemillenial
Beginner
Beginner
Good Day
I would like to know how do you link Duo Mobile to your Instagram , the problem is the process is a little different compared to the last time . I would really like a tutorial on how to set it up step by step . If I generate a Password for duo mobile what does it mean ? Is it different compared to Instagram . A new version of the tutorial would be much appreciated
DuoKristina
Please refer to Instagram’s instructions for setting up an authentication app for two-factor authentication: https://help.instagram.com/1582474155197965 and be sure to save the recovery codes Instagram gives you in a safe place as Duo cannot help you recover access to Instagram.
Duo, not DUO.
