IOx Application not starting automatically
Justin Chin-You
Hi All,
I have an IOx Application with the following Package.yaml. I have no idea why but everything seems to load in fine but the target parameter doesn't seem to start. If I open a console and run it, the app runs fine. However the moment I close the console the app dies as well.
Anyone with any ideas I'd really appreciate it.
descriptor-schema-version: "2.2"
info:
description: "Test App2"
version: "1.0"
author-link: "http://www.cisco.com"
author-name: "Cisco Systems"
app:
cpuarch: "x86_64"
type: docker
resources:
   profile: c1.small
   network:
       interface-name: eth0
       ports:
         tcp:
           - 8284
startup:
   rootfs: rootfs.tar
   target: ["/opt/mqttfolder/mqttappExec"]
Steve Zhang
The main reason is it prints too much information in the console. So it is recommended to put all these console information in a log file.
Thanks Steve! Giving it a go and see if we can adjust!
