IR1101 Application Hosting: Network interface IP address
Hi everyone!
The information related to the network interfce when I execute the 'show app-hosting detail' command does not include the IP address, as shown below. Shouldn't information related to the IP address be displayed? The commands to configure the IR-1101 network interface (GigabitEthernet interface) and the VirtualPortGroup are also shown below.
Router#show app-hosting detail
App id : SGG
Owner : ioxui
State : RUNNING
Application
Type : docker
Version : 1.0
Description : Smart Grid Gateway
Path :
Activated profile name : c1.tiny
Resource reservation
Memory : 32 MB
Disk : 10 MB
CPU : 100 units
Attached devices
Type Name Alias
serial/shell iox_console_shell serial0
serial/aux iox_console_aux serial1
serial/syslog iox_syslog serial2
serial/trace iox_trace serial3
Network interfaces
eth0:
MAC address : 52:54:dd:a8:f9:d1
Router#configure terminal
Router(config)#ip routing
Router(config)#interface gigabitethernet 0/0/0
Router(config-if)#no switchport
Router(config-if)#ip address 192.168.0.51 255.255.255.0
Router(config-if)#no shutdown
Router(config-if)#exit
Router(config)#interface virtualportgroup 0
Device(config-if)#ip address 10.1.1.1 255.0.0.0
Device(config-if)#end
Router(config)#app-hosting appid SGG
Router(config-app-hosting)#app-vnic gateway0 virtualportgroup 0 guest-interface 0
Router(config-app-hosting-gateway0)#guest-ipaddress 10.1.1.3 netmask 255.0.0.0
Router(config-app-hosting-gateway0)#app-default-gateway 10.1.1.1 guest-interface 0
Router(config-app-hosting)#end
Thanks in advance.
Andre Chrcanovic
Alexander Stevenson
Well, the IR1101 runs IOS XE. On that OS, to reveal the IP Address-related info, it seems we need to specify appid and the app name. Therefore, in this case, the command would be:
sh app-hosting detail appid SGG
I hope this helps!
