Is there any way to use USB port for serial connectivity into GOS?
dsdjung73
While understanding that there are existing serial ports on IR829, I am wondering whether USB port can be used for serial connectivity into GOS.
Steve Zhang
Hi David,
Currently the USB port is only available as USB storage for GOS. It may support USB Serial or other in later version.
As you mentioned, you may use the two serial interfaces of IR809 directly currently.
Steve
