Is this a supported Configuration ?
vbeckers
Hi Guys,
I am trying to use a bridge group for interface gig 5 so the can obtain an ip address. The OS seems to get an ip address and I can ping it but I see this message come up once I add gig 5 to the bridge-group.
000416: *Oct 17 17:41:40.580: %IOX-6-HEARTBEAT_TIMER_EXPIRED: IOX Heartbeat timer expired.
interface GigabitEthernet5
no ip address
ip virtual-reassembly in
duplex auto
speed auto
ipv6 enable
bridge-group 1
interface BVI1
description Kit Wireless Data
ip address 10.1.1.200 255.255.255.240
ip nat inside
ip tcp adjust-mss 1000
bridge 1 protocol ieee
bridge 1 route ip
show iox host list detail   - OS status showing as Unknown
IOX Server is running. Process ID: 327
Count of hosts registered: 1
Host registered:
    IOX Server Address: FE80::242:68FF:FE85:D5EC; Port: 22222
    Link Local Address of Host: FE80::1FF:FE90:8B05
    IPV4 Address of Host:       10.1.1.201
    IPV6 Address of Host:       fe80::1ff:fe90:8b05
    Client Version:             0.4
    Session ID:                 3
    OS Nodename:                kit-6926-GOS-1
    Host Hardware Vendor:       Cisco Systems, Inc.
    Host Hardware Version:      1.0
    Host Card Type:             not implemented
    Host OS Version:            1.1.2.0
   OS status:                  UNKNOWN
    Interface Hardware Vendor:  None
    Interface Hardware Version: None
    Interface Card Type:        None
    Applications Registered:
        Count of applications registered by this host: 0
Victor
Steve Zhang
Hi Victor,
BVI is supported by IR829 IOS/IOx. Do you set the irb, gos-pool, vlan, etc.?
Here is my configure info for your reference. Hope it helps.
ip dhcp pool gospool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 64.104.123.144
bridge irb
interface GigabitEthernet1
switchport access vlan 100
no ip address
no ip address
duplex auto
speed auto
ipv6 enable
bridge-group 1
interface Vlan100
ip address 10.74.69.119 255.255.255.0
ip nat outside
interface BVI1
ip nat inside
Steve
Thanks Steve.
I tried that config and I noticed the following which seems to be an odd behaviour and more like a bug.
1 - Eth0 gets an ip address and its singable from the local interface however as you can see it doesn't show the ip address on the host detail.
kit-6926#ping 192.168.1.3
Sending 5, 100-byte ICMP Echos to 192.168.1.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
kit-6926#show iox host list detail
Count of hosts registered: 0
    IOX Server Address: 0.0.0.0; Port: 22222
2 - Once I remove interface gig 5 from the Bridge-group 1 the heartbeat seems to work and I also get get an output from the host list
kit-6926(config)#int gi5
kit-6926(config-if)#no bri
kit-6926(config-if)#no bridge-group 1
004106: *Oct 18 12:17:20.674: %LINK-3-UPDOWN: Interface BVI1, changed state to down
004107: *Oct 18 12:17:21.332: %IOX-6-SOCK_CONNECT: Received socket connection request from IOX Client
004108: *Oct 18 12:17:21.674: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
004109: *Oct 18 12:17:22.346: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_REGISTER from IOX Client
004110: *Oct 18 12:17:23.350: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode
IOX_REQUEST_GET_TIME from IOX Client
Host registered:
    IPV4 Address of Host:       192.168.1.3
    Client Version:             0.4
    Session ID:                 6
    OS status:                  RUNNING
and obviously once I remove the bridge-group command the server no longer responds to pings
Success rate is 0 percent (0/5)
kit-6926#
If you could help me debug or send me some about how the heartbeat works I would appreciate it.
Victor
