1313
natchokk@cisco.com
Clarification on : AMP for Endpoints and AMP for Networks
I joined cisco recently . i would like to know about
AMP for endpoints used to scan/discover laptops, desktops , server irrespective of OS?
AMP for Networks used to scan/connect devices like Switches, routers , chassis etc ?
whether both called as connectors ?
AMP for endpoints is similar to Microsoft SCCM?
Can someone please clarify
5 REPLIES 5
Matthew Franks
Nathan,
I suggest you start with the AMP 101 training.
Matt
Thank you Matthew
Troja007
Hello natchokk@cisco.com,
AMP for Endpoints is an Endpoint for EPP/EDR/XDR, and part of the Cisco SecureX Architecture. This includes the local protection of the OS and application, the EDR part for Threat Hunting and Investigations and with SecureX the automation/orchestration part.
As SCCM, from my point of knowledge, is for deployment, you cannot compare them in any way.
Agree with @Matthew Franks, the 101 Training gives you a very good insight into the AMP world.
Attached two screenshots, just to show some parts of the EPP/EDR/XDR part with AMP for Endpoints. Keep in mind, this is still an overview.
Greetings,
Thorsten
Many thanks Thorsten
Ruben Cocheno
Enthusiast
natchokk@cisco.com
i do agree with @Troja007  and @Matthew Franks , a lot to cover on AMP but also what can you have attached to it as part of the Cisco Security Portfolio.
Please mark it helpfull if it was the case, and i have this problem too. Double touchdown is amazing. Thanks to make Engineering easy.
Create
Recognize Your Peers
Polls
Which of these topics should we host an event in the Community?
Top Choice: ISE- Guest and Posture Troubleshooting (39%)
Content for Community-Ad
