FindIT Network Manager web ui default credentials
russel.bacha
installed FindIT Network Manager 2.1.1, But i can't access the web ui using cisco username and password,
even if i reset it from cli using finditmgr recoverpassword i still can't access the web ui using cisco as user and password.
please help.
Sujoy Paria
finditmgr recoverpassword tool resets the password for the cisco account to the default of cisco, or, if the cisco account has been removed, it will recreate the account with the default password. So, in both case username and password ‘cisco’ should work. Did you tried different browser after clearing the cache and history, stored password (if any)?
