About SSL Policy with vFMC
yunsh63
Hi.
Using vFMC and FP 8140.
OS version are 6.2.3.4.
And FP is using Passive mode.
This situation, I config the SSL Policy.
Make object, Make a Rule and Deploy.
But SSL Policy is not work.
Is the passive mode not working the ssl policy?
Thanks.
Marvin Rhoads
In a passive deployment, SSL decryption options are quite limited. For instance, you cannot decrypt and resign as that is necessarily an active deployment characteristic.
https://www.cisco.com/c/en/us/td/docs/security/firepower/623/configuration/guide/fpmc-config-guide-v623/understanding_traffic_decryption.html#ID-2252-00000029
