Adding FTD to FMC
donnie
Hi all,
I am trying to add my cisco firepower 2130 appliances to my FMC.
According to the link (https://www.youtube.com/watch?v=eshXpBPPKPg), from the console CLI, after entering the default username and password, it should prompt me to accept EULA after which I can proceed to set my management interface ip and specify my FMC ip address using "configure manager add x.x.x.x".
But after I enter the default username and password there is no EULA. And there is only a limited amount of commands as below. Why is this so? How do I proceed, please advise.
1)acknowledge
2)backup
3)clear
4)commit-buffer
5)connect
6)discard-buffer
7)end
8)exit
9)gcov
10)scope
11)set
12)show
13)terminal
14)top
15)up
16)where
Abheesh Kumar
Enter below command to assign IP address for management port and then add to FMC
connect ftd
configure network ipv4 manual <mgmt0 IP> <netmask> <gateway> management0
To Add to FMC
configure manager add <FMC IP> <KEY>
Hope This Helps
Abheesh
