Beginner
ASA 5506-x - ASDM cant load config from device
I have a ASA 5506-X i have updated all the software to the following versions
ASDM  7.12.2
ASA 9.8.4
Firepower 6.0.0-1005
It will load up asdm and comumnicate with the firepower module but then will fail to load the cofig from the device
I am using a windows 10 laptop, not sure of the java version at the moment
Any ideas on why this would happen?
Everyone's tags (3)
1 REPLY 1
Beginner
Re: ASA 5506-x - ASDM cant load config from device
i have found a work arround for this, i used a windows 7 laptop with the latest java version, this has done what i need
