ASA 5545X, Firepower Issue
macfrist38
Hi All,
I have an urgent Issue, i bougth 2 ASAs 5545x with Firepower, both ASAs have Sourcefire inside flash, but only one has the status UP.
when I issue show module command,
ASA1
ciscoasa# sh module
Mod  Card Type                                    Model              Serial No.
   0 ASA 5545-X with SW, 8 GE Data, 1 GE Mgmt     ASA5545            FCH19207Y7G
 ips Unknown                                      N/A                FCH19207Y7G
cxsc Unknown                                      N/A                FCH19207Y7G
 sfr Unknown               N/A           FCH19207Y7G
Mod  MAC Address Range                 Hw Version   Fw Version   Sw Version
   0 d8b1.9040.ba11 to d8b1.9040.ba1a  1.0          2.1(9)8      9.2(2)4
 ips d8b1.9040.ba0f to d8b1.9040.ba0f  N/A          N/A
cxsc d8b1.9040.ba0f to d8b1.9040.ba0f  N/A          N/A
 sfr d8b1.9040.ba0f to d8b1.9040.ba0f  N/A          N/A
Mod  SSM Application Name           Status           SSM Application Version
 ips Unknown                        No Image Present Not Applicable
cxsc Unknown                        No Image Present Not Applicable
Mod  Status             Data Plane Status     Compatibility
   0 Up Sys             Not Applicable
 ips Unresponsive       Not Applicable
cxsc Unresponsive       Not Applicable
 sfr Unresponsive       Not Applicable
Mod  License Name   License Status  Time Remaining
 ips IPS Module     Disabled        perpetual
ASA2
ciscoasa# sh module
 sfr FirePOWER Services Software Module           ASA5545            FCH19207Y7G
 sfr d8b1.9040.ba0f to d8b1.9040.ba0f  N/A          N/A          5.3.1-152
 sfr ASA FirePOWER                  Up               5.3.1-152
 sfr Up                 Up
I have tried these commands in order to recover firewall
sw-module module sfr recover configure image disk0:asasfr-5500x-boot-5.3.1-152.img
sw-module module sfr recover boot
The state sill the same, but i can connect to the firepower module via session sfr console.
Please can you help me ?
Marvin Rhoads
If you've booted the recovery image, you have a partial system setup. You need to go into the module using the session command and run setup. Once you have a bootstrap configuration in place you can complete the recovery process by installing the full image.
Something like this:
ciscoasa# session sfr console
Opening console session with module sfr.
Connected to module sfr. Escape sequence is 'CTRL-^X'.
Cisco ASA SFR Boot Image 5.3.1
asasfr login: admin
Password: Admin123
Then run setup, followed by "system install" to load the full image package (pkg) as follows::
asasfr-boot> system install ftp://<FTPusername:FTPpassword>@<FTP IP>/asasfr-sys-5.3.1-152.pkg
Verifying
Downloading
Extracting
Package Detail
Description: Cisco ASA-SFR 5.3.1-152 System Install
Requires reboot: Yes
Do you want to continue with upgrade? [y]: Y
Warning: Please do not interrupt the process or turn off the system.
Doing so might leave system in unusable state.
Upgrading
Starting upgrade process...
Populating new system image
Reboot is required
Once you reboot, the sfr module should show as up. You can then log back in (using admin / Sourcefire), accept the EULA and finish by re-setting the addressing and then adding the manager definition.
5 Replies 5
Marvin Rhoads
asasfr login: admin
Password: Admin123
Verifying
Downloading
Extracting
Package Detail
Upgrading
Reboot is required
Hello Marvin,
We tried the command but we got an error.
ERROR: Failed opening console session with module sfr. Module is in "Unresponsive" state.
Please try again later.
Please start a new thread for your issue. Let us know the steps you've taken so far.
macfrist38
Hi Marvin,
Thanks very much, I tested and it is working well.
Thanks again.
Hi Macfrist38,
Good Day! How did it worked? Thank you in advance!
