asa with firepower to FTD
nareh84
Level 3
Level 3
hi,
if one have bought ASA5516-FPWRBUN (see attached). i beleive its ASA (5516-x) with firepower. this is not deployed yet. is it possible to configure unified image i.e FTD on ASA rather than separate images (i.e ASA with firepower) using the support (CON-PSOP-ASA556F9 and CON-PSBU-VM2)bought with it.
nspasov
Hi there! Yes, you can deploy the Firepower Threat Defense (FTD) image. There are a couple of things that you will need to do:
  • Re-Image the ASA with the FTD Image. See here
  • Sign up for a Smart Licensing Account (If you have not done this before). FTD only works with smart licenses. See here
  • Convert your traditional licenses (In this case the TAMC) to smart licenses. You can do this once you get access to a Smart Licensing Account
I hope this helps!
Thank you for rating helpful posts!
