191
Beginner
Change Destination PORT HTTPS to Spesific port
Hello guys,
I have made nat rules so that the FMC private ip can be accessed by public ip, but I want to make the HTTPS port specific, I have tried to create a new port object named HTTPSFMC port (20443) when I put it in the policy port, I try accessing the FMC IP (https: //IP_FMC:20443) it can't be opened
If I make a port in the policy -- > the default HTTPS (443) when I access the public FMC ip can be accessed
do you have any suggestion or solution
thank you
Everyone's tags (1)
2 REPLIES 2
VIP Advocate
Re: Change Destination PORT HTTPS to Spesific port
Have you specified the ports in the NAT rule you have created? Or are all ports being translated to the FMC?
Please remember to rate and select a correct answer
Beginner
I tried to put "translate destination port" with 2443 in nat rules for specific, but it didn't work
i have 4 nat, 3 of them PAT
and 1 is static NAT for access FMC via ip public
do I have to apply it in the nat rules "translated destination port", and in the policy as well?
