12-03-2019 01:02 AM - edited 02-21-2020 09:44 AM
HI All
I Have a Cisco 5555-x with Firepower Services which is previously managed with FMC(with Cisco ASA5555 Firepower Control, IPS,AMP and URL Licenses). Now, I want to manage it with ASDM. when I connect to firewall via ASDM, I see only "ASA FirePOWER Status" Tab(no configuration TAB). As I surfing the web, I got that in Setup Wizard(if it is not correct,please let me know), I need to enter firepower network configuration(as same as in my current firepower network configuration). My question is that, after finishing wizard setup, all the previous firepower configuration and licenses will be deleted or not?
best regrads
Sina HR.
Solved! Go to Solution.
12-03-2019 03:43 AM
12-03-2019 09:33 AM
The installed policy resides on the target managed device.
However, there's no provision for that policy to be synced back "up" when a new type (for instance changing from FMC to ASDM) or different instance of the same type of manager (in the case of FMC) is configured.
Licenses need to be rehosted as I noted.
12-03-2019 03:43 AM
12-03-2019 05:30 AM
Hi Marvin Rhoads.
thanks for replying.
I have to say that the FMC VM is deleted and there is no Backup/snapshot from previous Network Security Administrator. If I want to install new FMC VM, i have to install license and policy again? in other words, all policy and licenses always installed in management center either ASDM or FMC and not in SFR Module?
Best Regards.
12-03-2019 09:33 AM
12-03-2019 09:11 PM
thanks so much Marvin.
Sina HR.
