602
Beginner
Cisco Firepower Management Center License
Hello
I hope everyone is fine.
Do I need a license (for FMC) to integrate an ASA with Firepower Services on an FMC appliance ?
Regards.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: Cisco Firepower Management Center License
You're welcome. Please mark the reply as a solution if it solved your problem.
5 REPLIES 5
Hall of Fame Master
It depends on your FMC.
FMC hardware appliances are not licensed per managed device - they are only subject to the hardware limitations.
FMC virtual appliances are licensed in 2- 10- or 25-device tiers.
Beginner
Hello marvin
Thank you for your return
Okay,
A last two questions if possible, what type of license do I need and about how much does it cost? (Only for one device on a virtual appliances)
Regards.
Hall of Fame Master
The entry level license is the 2-device one. Part number SF-FMC-VMW-2-K9. List price US$500.
Beginner
Hello Marvin
Thank you so much for your great support and informations.
Have a good day.
Regards.
Hall of Fame Master
