03-12-2019 09:03 AM - edited 02-21-2020 08:56 AM
I am running Cisco FTD on ASA. i want to upgrade the patch as i am running on 6.2.3 version to latest patch.
Is there any correct patch as it says multiple paths which is getting confusion.
Can anyone support me on the same.
03-12-2019 08:31 PM
The current latest 6.2.3 patch is 6.2.3.10. If you are running any older 6.2.3.x release you can upgrade directly.
If you use FMC, it must be upgraded first as any managed devices cannot be at a higher version than the FMC, including patch versions.
Log in to Community
