Cisco FTD configuration with dual ISP
Aqi Shah
Dear All,
We have some requirement related to cisco FTD form FDM.
What I need in configuration ?
There is a Cisco Core switch installed in same DC which is configured as Layer 2, one separate L3 VLAN needs to be created which will be forwarding all the traffic of that VLAN to this firewall.
Enable NAT
We have 4 internet links, need to enable load balancing and auto failover
Configuring 3 servers in DMZ zone of Firewall (PAT is required)
how can we configure load balancing form FDM although it not support PBR
or how can we configure dual static route on FTD via FDM because it is not allowing us to configure this?
nspasov
Hi there! I am a bit confused by the title of your question which includes " Dual ISE" but no mentioning of ISE in the actual question so I am guessing you meant "Dual ISP? :)
Now to answer your question, you can configure PBR with the help of FlexConfig:
https://www.youtube.com/watch?v=lakHhw9CR5Y
Thank you for rating helpful posts!
Yes it is ISP have you read my full message i have mentiond via FDM not FMC.
Yes, I read the entire thread and my answer still stands as FlexConfig is supported in both FMC and FDM. You can use the youtube video as a reference.
