configure snort preserve-connection disable at FirePower 8370
subrun.jamil
Hello All,
I was checking to see if below command I can configure at FirePower 8370 Stack. But once I login to one of the 8370 stack member ( 8350 ) , i am not able to find this command available. Also how can I see this preserve-connection is enabled or not ?
@subrun.jamil Yes, as long as you are running FTD software 6.2.0.2 or later.
Since 6.2.3 that setting is the default.
Marvin Rhoads
That's an FTD 6.2.0.2 or later command. I don't believe it applies for classic Firepower devices such as the 8300 series.
https://www.cisco.com/c/en/us/td/docs/security/firepower/640/configuration/guide/fpmc-config-guide-v64/policy_management.html?bookSearch=true#concept_33516C5D6B574B6888B1A05F956ABDF9
Thank You Marvin, is this option available at FirePower 9300 Devices ?
