Firepower 7100 series - unable to execute few commands
Dear Cisco Community,
I was doing preventive maintenance on Firepower 7100 series, however I was not able to execute few commands in CLI, please find the snap attached at the end for reference.
Below are the command,
  1. show version
  2. show memory
  3. show power-supply-status
  4. dir flash
  5. dir nvram
  6. Show file systems
Firepower OS is running over a Linux OS. If you switch to "expert" mode you can use standard Linux commands to query system variables.
FMC does manage the 7100 series. It uses a set of programmatic health monitor queries as opposed to show commands. You cannot execute cli commands on the 7100 series sensor from FMC.
You can see the device health status in FMC under System > Health > Monitor and then click your sensor.
Here's an example:
Marvin Rhoads
The problematic commands you cited aren't supported on Firepower OS.
Was there some source that made you expect they would be?
@Marvin Rhoads Thanks for your response on my query...
So basically those commands are supported only on Cisco ASA, not on firepower appliance, is it? If so will you be able to provide me link to commands that are supported by firepower?
If I understood the architecture correctly, the Firepower appliance is connected to FMC, are there ways to execute these commands from FMC?
Here's an example:
@Marvin Rhoads I shall try out the options you have provided and come back with results, thanks for your response.
