07-24-2019 10:52 PM - edited 02-21-2020 09:20 AM
As planning is to be done on the firepower 9300, I would like to check if the specification such as heat dissipation and typical power consumption may be available?
Appreciate on the help for any suggestion on it :)
Solved! Go to Solution.
07-25-2019 04:29 AM
Please refer to the hardware installation guide:
and datasheet:
Power is covered in both. (I didn't see heat output in either one though.)
07-25-2019 04:29 AM
and datasheet:
07-28-2019 06:41 AM
Hi Marvin,
Thank you for the information. For the heat, I have made use of1 W = 3.412142 BTU/hr and applied on it as a reference:)
