Community Helping Community
233
Beginner
FMC 6.4 client support for pxGrid 2.0
New REST API based pxGrid 2.0 is supported in ISE 2.4, and is backward compatible with clients that only support XMPP based pxGrid 1.0 according to this https://developer.cisco.com/docs/pxgrid/#!parity-chart-between-pgrid-1-0-and-pxgrid-2-0/support-legacy-pxgrid-clients
Couldn't find a reference in the docu for FMC 6.4 if it supports pxGrid 2.0 (as a client) or still the old pxGrid 1.0 version. Do we know if FMC 6.4 supports REST based pxGrid 2.0?
Rick.
1 REPLY 1
Re: FMC 6.4 client support for pxGrid 2.0
Hi Rick-
As of the latest release of Firepower (6.5), the PxGrid client is based on version 1. The utilization of version 2 is planned in future release of Firepower.
I hope this helps!
Thank you for rating helpful posts!
Content for Community-Ad
FusionCharts will render here
