FMC 6.4 GUI/web interface slow
SN9
I have installed vFMC 6.4 with 4CPUs and 8GB RAM for testing purposes. Accessing the GUI is very slow and navigating between the tabs/options taking long time. CPU and RAM usage are normal.
Do we need to change any setting to make the GUI/Web interface faster?
SN9
I have tried fresh install still facing the same issue even after increasing the CPUs to 8 and RAM to 16GB.
Any one else also facing the same issue?
Below is the default host requirements for the deployment of Firepower Management Center Virtual. Increase the Memory to 32Gb and check.
Hope This Helps
Abheesh
Marvin Rhoads
FMC just has a lot of things going on under the covers and is suffering from some inefficient architectural underpinnings (multiple suboptimal databases, not taking full use of multiple cores etc.). Even if you give it 128 GB or RAM and 16 cores it won't get significantly faster.
