234
Contributor
fmc and logging rules
i have fmc+ftd 2110 and almost 100 rules . can i enable logging for all rules or will it cause cpu and storage issue for the fmc?
1 REPLY 1
Hall of Fame Master
Re: fmc and logging rules
If the events per second overwhelm the FMC it will just drop some events. It will note it with a health monitor alert ("frequent drain of unprocessed events").
Ability to process events depends on the model of FMC. Storage is not a significant issue - oldest events will be dropped out of storage once the database reaches its limit.
