FMC integration with Azure based AD
sameesin
Has anyone worked on integrating FMC with Azure based AD. Are there any challenges or caveats that one would face?
Sameer Singh
Francesco Molino
You meant a local AD synced with Azure? I'm not an AD expert but in all my deployment, customers had still local AD node, not sure you can directly integrate with Azure (but i may be wrong)
I've done it but not directly from FMC. In between there was an ISE-PIC.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
