01-29-2019 08:20 AM - edited 02-21-2020 08:42 AM
I am configuring my company FMC security intelligence part. But in the available objects tab, I didn't see the Cisco feed objects as: Malware, Phishing, Bots, etc.
Any one can help me?
Thanks.
Solved! Go to Solution.
02-04-2019 05:00 AM
If you have a smart license account, you might be able to use a Satellite server. It will act as a Proxy between the Firepower device and Internet. Checkout Registration of a Firepower Management Center to a Smart License Satellite Server for more info
01-30-2019 06:12 AM - edited 01-30-2019 06:14 AM
Have you checked that your FMC can connect to the intelligence feed? You can ssh into the FMC and do a
"sudo telnet intelligence.sourcefire.com 443" to verify that you are able to connect.
Here is a link to a troubleshooting guide for security intelligence Troubleshoot Security Intelligence
01-30-2019 12:02 PM
01-30-2019 08:01 AM
Make sure you have Base/IPS license added to FMC and applied to the device, FMC should be able to download the latest updates.
01-30-2019 12:10 PM
01-30-2019 12:14 PM
02-04-2019 05:00 AM
02-04-2019 06:21 AM
