Community Helping Community
402
FMC1000-K9,FTD2110 Case: Events Logging and Connection not showing. Pls share case Thx.
FMC is not showing any event and logging connection, I've configured everything as below1.JPG2.JPG3.JPG
Information
    -FMC1000-K9  Version 6.3.0.3
    -FTD2110  Version 6.3.0.3
7 REPLIES 7
Hall of Fame Guru
Re: FMC1000-K9,FTD2110 Case: Events Logging and Connection not showing. Pls share case Thx.
Are you seeing no connection events at all (under Analysis > Connections)?
I don't see anymore. thx
Dead end ,any idea where to start my troubleshooting?
Hall of Fame Guru
Your policy setup seems to be correct as far as what you shared already.
The sftunnel process that connects the sensor to FMC may be hung.
It would be best to open a TAC case and they can do some quick checks from the cli to verify and confirm that communications are established properly.
To Marvin
Thx for support. I will take your advice....Have you ever had that problem?
Hall of Fame Guru
Yes I have seen it before. The cause may vary but one thing to check is as follows below (from the FMC cli). Interpretation of the output is not immediately obvious so that is why I recommend a TAC case to assist.
Get the Current Process status:
  • pmtool status | grep -E "Waiting|Down|Disable|Running"
Restart all the processes:
  • /etc/rc.d/init.d/console restart && tail -f /var/log/messages
Get the Processes status again:
Hi Mavin
Thank you for support. It's true as yousaid.
Process service SFDataCorrelator - is Waiting
Content for Community-Ad
FusionCharts will render here
