Beginner
FTD CSCvk33923 High disk usage after deleting managed FTD device from FMC
Hi all,
The workaround from Cisco is below:
Workaround:
> remove or move /ngfw/var/cisco/deploy/current-policy-bundle.tgz
> No new deployment packages files will be created under tmp folder after that
> Remove files created before by running:
rm -r /ngfw/var/tmp/*
I am looking for clarity for the remove or move /ngfw/var/cisco/deploy/current-policy-bundle.tgz. Has the whole directory structure to be moved/removed or just the file: current-policy-bundle.tgz
Can you also confirm command syntax.
thanks
Ian
1 ACCEPTED SOLUTION
Re: FTD CSCvk33923 High disk usage after deleting managed FTD device from FMC
Hi Ian,
Sure, command would remain same.
rm /ngfw/var/cisco/deploy/current-policy-bundle.tgz
rm /ngfw/var/tmp/*
Hope it helps,
Yogesh
3 REPLIES 3
Just the file current-policy-bundle.tgz needs to be removed.
Hope it helps,
Yogesh
Beginner
Yogesh,
Thanks for the clarification.
For sanity sake, can you please verify exact cli syntax to remove this file.
being ultra cautious.
Ian
Hi Ian,
rm /ngfw/var/tmp/*
Hope it helps,
Yogesh
