Community Helping Community
419
Beginner
FTD Default EIGRP Hello / Hold Timers
I noticed the default hello/hold timers on FTD (Cisco FTD 4110 6.3) are 60/180 seconds, although the link speed is more than T1 speed - link is 20 Gbps. The other end of my FTD is a Catalyst 9500 with default timers of 5/15 seconds. I can change the FTD timers through FlexConfig. Need to understand why the defaults on FTD are higher and Is it a Cisco recommendation to keep timers higher on the FTD (and potentially match at the other end as well)?
> show running-config all interface Port-channel 1.950
interface Port-channel1.950
mac-address e210.1732.4206 standby e210.1732.4207
vlan 950
nameif Inside
cts manual
propagate sgt preserve-untag
policy static sgt disabled trusted
security-level 0
ip address 10.173.242.6 255.255.255.248
delay 100
no authentication key eigrp 18
no authentication mode eigrp 18
hello-interval eigrp 18 60
hold-time eigrp 18 180
split-horizon eigrp 18
> show interface Port-channel 1.950
Interface Port-channel1.950 "Inside", is up, line protocol is up
Hardware is EtherSVI, BW 20000 Mbps, DLY 1000 usec
VLAN identifier 950
MAC address e210.1732.4206, MTU 1500
IP address 10.173.242.6, subnet mask 255.255.255.248
Traffic Statistics for "Inside":
1195852 packets input, 75673947 bytes
318932 packets output, 24815909 bytes
4278 packets dropped
Rick.
1 REPLY 1
Beginner
Re: FTD Default EIGRP Hello / Hold Timers
Hi Rick,
You'll most likely get a definitive answer from Cisco only but from my experience it's set due to stability. I wouldn't use as a typical router.
Content for Community-Ad
FusionCharts will render here
