08-10-2019 02:28 PM - edited 02-21-2020 09:23 AM
I applied a new policy to an FTD, but now I need to know which policy was previously applied. I searched system> monitoring> audit but could not find the information.
Does anyone know where I can find this information?
Solved! Go to Solution.
08-15-2019 09:42 AM
Not if you're just modifying a policy and redeploying it. If you make a copy and change the name prior to deployment then you can compare policies.
08-12-2019 07:17 AM
The capability to see what you're asking is pretty limited although some recent changes have helped a bit.
What version are you running and are you deploying from FMC or FTD?
08-13-2019 09:58 AM
Hi, Tks Marvin!
I´m running version 6.2.3.2 and I´m deployng from FMC.
Do you believe that there is some command in FTD that could show it?
Regards.
08-15-2019 09:42 AM
