09-24-2019 09:48 PM - edited 02-21-2020 09:31 AM
I am running frp9300 inter-chassis cluster and I have a FMC HA running.
When i am trying to register the logical FTD it connects to primary FMC fine but doesn't register under secondary FMC as its on a different subset.
FTD Br1: 192.168.1.2
GW:192.168.1.1
Primary FMC: 192.168.1.30
Secondary FMC: 192.168.11.30
Please can someone help me how i can enter the route for Br1 interface so that it reach to 2nd FMC to complete the register process? which is currently always show as pending when i use
> show managers
for directly connected network it shows completed but for other it stay as pending and do nothing and I am also getting messages on FMC part of the Ha config with secondary FMC not sync as these register devices only appearing under primary FMc not secondary FMC?
Please can someone advice?
09-24-2019 10:48 PM
09-25-2019 03:54 AM
To add a gateway to your FTD management interface, just update the network configuration from the FTD device's cli.
Use the following syntax:
configure network ipv4 manual <ftd mgmt address> <netmask> <gateway>
07-27-2020 03:27 AM
Did you find a fix on this issue?
I have similar setup
FTD -> FMC Primary and FMC Secondary in HA.
FTD x.x.x.x -> FMC Primary x.x.x.y Succeeds
FTC -> FMC Secondary Fails
01-27-2024 11:18 AM
Hi @khalid.meraj , did you managed to resolve it? I have similar setup and as per documentation, we can do HA in geographical location or different subnet but seems to be having some issues when registering the FTD to both FMCs.
01-27-2024 11:45 AM
That was long post and old Code, tell us your environment and Code running ?
