How to monitor traffic by IP from Firesight
Alvaro Rugama
Hi everyone
I'm looking for a way to monitor traffic by ip address from my FireSight, we have an ASA5516X with firepower services.
Hope you can help me with this.
Best regards
yogdhanu
You can do it from your firesight.
Just navigate to connection events and filter out the IP address you want to see or it will just show all the IP's
Or you can navigate to dashboard and there are plenty of graphs which can help you.
Hope the 5516 is being manged by the firesight.
Let me know if it helps.
Yogesh
yogdhanu
Yogesh
Thank you for the reply.
Actually, I was looking this option, but it was empty. What I needed was to enable logging on the access-rules.
To enable logging , you need to go to : Policies >Access control policy , Edit the policy being used . Edit the rule for which you want to enable logging and then go to Logging >Beginning of connection.
Aastha Bhardwaj
Rate if that helps!!!
