Cisco Community Designated VIP Class of 2020
370
Beginner
How to rollback a change in the policy that has not been deployed on FTD from FMC ?
I noticed one of the policies on the FMC is out of date i.e not updated/deployed on the Firewall.
I am not aware what changes were done on the policy and I want to avoid going through each and every rule to find that out.
Is there way I can rollback changes on the policy to match with the policy that is already on the firewall ?
1 REPLY 1
VIP Advisor
Re: How to rollback a change in the policy that has not been deployed on FTD from FMC ?
Unfortunately you can't. This is an existing enhancement request:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvm28872/?rfs=iqvred
If you have a backup, you can restore it.
I know some guys at the TAC can clear the db but not all are doing this.
You can go under the system menu then monitoring and audit, you'll be able to see who did the change and click on the detail to see what change has been done.
If someone has exported the policies, you can re-import then under ACP menu.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Content for Community-Ad
FusionCharts will render here
