Beginner
If ASA config can be converted to FTD and uploaded to FMC, then why does an FTD config have to be manually added to FMC ?
in addition to the question in the title, how can I effectively add FTD config manually in FMC especially for some configs such as below which are not very straight forward available in FMC ?
 cts manual
  propagate sgt preserve-untag
  policy static sgt disabled trusted
access-list NGFW_ONBOX_ACL remark rule-id 868326999: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 868326999: L5 RULE: Device_Enroll
access-list NGFW_ONBOX_ACL advanced permit tcp ifc outside any object Device_Enroll eq https rule-id 868326999 event-log both
Also, in FTD config, interfaces begin with Ethernet1/1....Ethernet1/n, however in FMC, after adding the FTD, it shows the interfaces as Gigabit Ethernet 0/1...Gigabit Ethernet 0/n. how can I ensure, I map the correct interfaces from FTD config (which was intially being managed locally) to FTD interfaces in FMC ?
