Cisco Community Designated VIP Class of 2020
488
Beginner
Importing a couple of FTD configs into FMC issue
Hi Everyone
I'm rather new to Firepower firewalls. I've basically got two ASA configs which i've converted using the FMC conversion tool. I have two 2130 firepower firewalls registered with FMC.  I imported the first config which went I think has gone in correctly. My problem is when i imported the config for the second Firepower. Under the objects tab, the i can see all the objects for both imported configs.  It seems like both configs are just "there" and arent related to the correct firewall.
My question is, how do i separate the imported config so that it applies only to the correct firewall?
Does anyone know of an idiots guide or can point me in the right direction please?
Content for Community-Ad
FusionCharts will render here
