Beginner
Install Firepower on Production Cisco ASA 5525-X
I have a pair of HA firewall 5525-X. It is running Cisco ASA Firewall with CX software. As CX is now out of sales, we are planning to migrate to Firepower.
Based on Cisco website:
https://www.cisco.com/c/en/us/support/docs/security/asa-firepower-services/118644-configure-firepower-00.html
Image for Firepower software is as below.
asasfr-5500x-boot-5.3.1-152.img - boot image
asasfr-sys-5.3.1-152.pkg - software image
I go to Cisco Download website and I only see image with format below:
Cisco_Network_Sensor_Patch-6.2.3.4-42.sh.REL.tar
I am very confused.
Where can I find the boot image and software image stated in the web link above? Is the procedures indicated from web link above still valid?
1 ACCEPTED SOLUTION
Hall of Fame Guru
Re: Install Firepower on Production Cisco ASA 5525-X
5.3.1 is still on the downloads site - you have to expand the tree on the left to see it.
However there's no reason to install that 4+ year old release.
Instead start with the 6.2.3 boot image and install package. Then patch it to the latest (currently 6.2.3.4) release.
https://software.cisco.com/download/home/286271172/type/286277393/release/6.2.3
Also make sure your ASA and ASDM software are current first. The recommended releases are currently ASA 9.8(2) interim build 38 and ASDM 7.9.2(152)
https://software.cisco.com/download/home/284143129/type/280775065/release/9.8.2%20Interim
https://software.cisco.com/download/home/284143129/type/280775064/release/7.9.2.152
2 REPLIES 2
Hall of Fame Guru
Beginner
Hi Marvin:
Thanks you very much for your advice.
Now I see where was my problem, I look at version 6.2.3.4, 6.2.3.3 but didn't see the img and pkg file.
Now I see it is available in 6.2.3
Appreciate your advice.
Now I can proceed with my work using version ASA 9.8 and Firepower 6.2.3.
