Intrusion policy, Policy out-of-date on device
dm
Hello!
I use ASDM to manage Firepower on ASA 5506-X.
I just found that  in  Configuration > ASA FirePOWER Configuration > Policies > Intrusion Policy > Intrusion Policy
my policy is always shown as Policy out-of-date on device.
I tried to change it, to change access control policy in which it is in use, did deploy- there is no changes,
it is always Policy out-of-date on device.
Could you tell me how to solve this?
Currently running software version: 6.2.3.10
Thank you!
13 Replies 13
dm
btw, upgraded to 11, no changes.
johnlloyd_13
Level 9
Level 9
hi,
did you click 'Click Store ASA FirePOWER Changes' at the bottom?
I have this problem on 3 devices, nothing helps...
gregghudson
I have this exact same problem. Nothing clears the error. I go into the IPS and click "Commit Changes", go to Access Control Policy (and it says 'Up-to-date') and click "Store ASA FirePOWER Changes",  then "Save Running Configuration to Flash" and even after 'deploy' it still show's "Out-of-date". And this is on 5 different firewalls!
I'm seeing this exact same problem as well.
Has anyone found a solution to this issue?
It could be caused by a corrupted entry with the database.
I recommend opening a TAC case to get into the level of troubleshooting that necessary to confirm and remedy the issue.
I don't think there is any corruption here but software bug :-)
Bugs can cause database corruption. :)
Cisco TAC says "known bug".
Did they supply a bug number?
