LDAP Connection failed to AD throw Firesight
aoun.ameur1
Hi all,
I have a problem to connect to AD when adding a new LDAP Server Connection
The error message is as below :
Show Detail :
Opening connection to LDAP server - servername:389 - administrateur
Current TLS Require Cert: 0
binding
ldap bind invalid credentials error: 49
The directory server is up servername:389
User Test
LDAP Server Primary Available
Search Filter Test...
binding
Pujita Patni
Hi Aoun,
Can you try putting the user name field in the username@domain format and then check the results.
Pujita
Pujita Patni
Hi Aoun,
Pujita
It's working now
Thanks a lot Pujita
I had the same issue, There seems to be a bug when you upgrade from 5.4 to 6.0
The path in the realm (ou= dc =) is not converted to the new required username.
