06-13-2017 11:10 AM
When configuring a BOM in CCW and after checking the datasheet, I am confused why 21xx and 41xx have three different appliances: NGFW, NGIPS and AMP. What I see is they all have the same software image and same price.
what are the differences? do they support different feature sets?
06-16-2017 12:22 AM
There's no difference as far as I know.
Cisco has inconsistently used the NGFW and NGIPS terms. It used to be the former was for ASA and the latter for devices running FirePOWER OS. However the FTD image has blurred that distinction. They did market a couple of "AMP Appliances" in the 3D series that had extra local storage packs pre-added for Malware storage.
As far as I can tell, it's a distinction that only matters to the people counting sales categories at Cisco. Like you noted, all run the same image and the licenses (putchased separately) are what determine the features available.
06-26-2017 01:43 AM
Hi, Marvin!
There are different software on the bundles under the top-level SKU FPR4120-BUN (for example):
FPR4120-ASA-K9
SF-FXOS4K-2.1-K9 + SF-FPR-ASA9.7.1-K9
FPR4120-NGFW-K9
SF-FXOS4K-1.1-K9 + SF-FPR-TD6.0.1-K9
FPR4120-NGIPS-K9
SF-FXOS4K-2.0-K9 + SF-FPR-TD6.1-K9
All of them has the same price but software differs, as you can see.
At the same time there are different datasheets for this products:
http://www.cisco.com/c/en/us/products/collateral/security/firepower-ngfw/datasheet-c78-736661.html
http://www.cisco.com/c/en/us/products/collateral/security/ngips/datasheet-c78-738196.html
Really confused with that %)
06-26-2017 08:36 AM
They all have FX-OS for chassis manaement - simply the version included from the factory differs. In all cases you should upgrade to the current FX-OS when implementing.
The package with an ASA logical device will naturally have the ASA image.
The other two SKUs include an FTD logical device so they have that image. Similar to FX-OS, you should upgrade those to the current version when deploying.
06-30-2017 04:45 AM
